Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My whirlpool cabrio top loading washer with corner dispensers had some coins trapped in the bottom of the basket. I can hear the coins and some water. When the washer goes into spin it apparently throws the coins in the bottom of the tub and they stop up the drain. I have removed the basket and gotten the coins out twice, but will continue to have this problem until I can get the remaining ones out of the bottom section fo the basket.
  • 20 Answers
You have to disconnect all wire connectors, inner basket, both pumps & Then unclasp the 4 shock rods then remove the whole inner assembly. Then turn the inner assembLy upside down & every which way until they all fall out. Like shaking quarters out of your piggy bank.
Posted on Sep 29, 2010
Where is the lint trap and how do i clean it?
If the model number is true in the blue this a top load washer there is no lint trap lint collects on the protrusions on the outer side of the basket and is washed away during the rinse drain spin cycle
Aug 28, 2014 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
My whirlpool cabrio has water trapped in the wash basket. Is this normal? Keep getting UL code and checked everything else.
I have the same issue. when I remove the wash basket from the tub the plastic parts all seem to have a lot of water trapped inside them. I am looking for a solution and may start my own question. not getting any fault code at all the washer runs as designed. but the dirty water trapped in the plastic top of and bottom of the wash basket is making the clean clothes smell like a dirty dish rag.
Sep 05, 2012 | Whirlpool WTW6400SW Cabrio Washer
After using my Whirlpool Cabio Top Load Washing Machine to do a load of laundry, I can still hear water sitting inside.....What can I do?
There water in the balance ring at top of basket/that has to be in it...Can you see water at bottom of basket?
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Water leaks from the basket of my top loading whirlpool washer. I've watched the water level go down as the water has filled into the tub.
Remove the back cover. Inspect the basket for any leakages by filling the water in the basket. If located weld it or seal it with ARALDITE adhesive. Also check the outlet valve at the base of the basket.ensure that outlet valve is seated properly. This should be able to fix the problem, if not then you have to call service engineer to heck the functioning of control panel.
Aug 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio washer sounds like it has coins under the basket when it goes through the spin cycle. how do i get them out?
Assuming that this is a Whirlpool Cabrio, see the following Whirlpool Service manual. It has sections on how to pull the agitators, tub etc.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 11, 2010 | Kenmore 22422 Top Load Washer
My Whirlpool Cabrio washer has some coins trapped in the inside of the machine. I need to find out how to remove the agitator to check inside for more coins.
They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
May 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have coins under the basket of my kenmore elite oasis he model 2806 how do remove the basket?
See the following Whirlpool Service Manual for their Cabrio washer. The Sears / Kenmore Oasis is basically the same machine so the procedures for pulling the basket should be the same.
Apr 26, 2010 | Kenmore 22422 Top Load Washer
Change in bottom of the bucket
ohter than preventing them fom going into machine, ther eis no way to stop them fom entering the outer basket'pump assy.. you can popo the top of the machine and tip it back, then by removing the plastic outer cover (covering the outer to inner tub) youll be alble to lift out the basket and retreive errent debris..
Feb 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Two dollar coin fell into a space between agitator and a drum.
you can pop of the agitaor ( held on by a 7/16 screw to the the inner tub will lift right out, it merely rests upon the spline, youll need to "pop" the main top first by "popping hte release clips. approximately 6 inches form either side between the main lid and the front panel are the clips, use a sturdy putty knife as these are tough to undo, the outer tub ring then simply unsnaps off and youll be able to remove the inner basket with no problem.
Nov 19, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,139 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
