Question about Home
I have a glacier bay 7032e-b6104 two handle bath room faucet. i just finished installing and water is leaking underneath from the middle of the three holes where the lift rod is. what's wrong??? tony
  • dylyn
    dylyn Mar 07, 2012
    I have this exact problem, same model number, brand new faucet. I noticed when the aerator is out, it doesn't leak. When I put the aerator back in, water starts flowing out that lift rod hole. A backflow problem? Leak or crack inside? I'd like the aerator in, because it's a pretty noisy, messy affair without it.
  • Cory Trares Jan 14, 2013
    I have the same problem with mine and the water is definetly leaking from the aerator and running down the faucet to the base. I am trying to find a replacement aerator but have not had any luck. Any ideas where to look for such a part? Home depot, where I bought the faucet, does not have any that will work. The aerator must have a female connection on it.
    Problem Solver:
  • 12 Answers
Sounds like you have a defective faucet. I'm guessing this is a new faucet and there shouldn't be any water leaking from between the faucet and the counter top. All the fitting above the counter top are factory fittings.
The only possibility I can think of is that if you didn't use a back up wrench when you installed it and you twisted the factory installed lines too far while tightening the water supply line to the faucet, you could have broken a weld on the faucets supply line where it is connected inside the faucet.
Posted on Oct 04, 2010
I have a Glacier Bay shower faucet that is getting increasingly harder to control water temperature out of shower faucet! Water temperature is very hot
check the hot water supply first and if needed adjust if to high and or check your anti scald setting --need to remove the center handle on the mixing valve
How To Adjust Glacier Bay Anti Scald Device Yahoo Video Search Results
Jul 31, 2017 | Glacier Bay Home
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
How to fix a Glacier Bay Bathroom Faucet/ Leonardo
Usually they have a small screw, but its hidden under a cap. Look at the handles you should see a small plastic cap sometimes colored red and blue for hot/cold. Using tip of small knife pop out the cap/plug. The screw holding the handle on is in there.
Mar 20, 2015 | Plumbing
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Glacier Bay bathroom faucet - 2 handle leaks
see if the housing itself will unscrew
Jun 06, 2010 | Garden
Our glacier bay two handle faucet (sink in half bath) leaks from the hot water handle. We've had the hot water turned off to avoid the problem. Now that cooler weather is coming we'd like to wash our...
If you the teapot style faucet directly on top of handle, the little round cap should come off so you can see the screw that lets you remove handle. The other style will have set screws on the outside of either handle. You will need a allen wrench.
Nov 04, 2009 | Plumbing
Home Logo
436 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
