One day there was a bios code and it's been down ever since. I here there are ways to back door clear this problem. I have the 350.00 extended warrante but the unit was opened. what do i do. where can i buy two double e proms part number IZ721.
Some motherboard passwords can be cleared by unplugging it from all power supply connections and taking out the motherboard battery, the one that looks like an oversized watch battery, if it has one. Another way is to throughly check the board for jumpers that may be labeled "passwd" "bios config" or similar. Remember when playing with jumpers to not change anything you don't understand and to put everything back when you are done.
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased:. Hope this helps
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
. Hope this helps
The board is a TekRam P5T30-B4E. While I have removed the battery and unplugged the power cord to the power supply from the outlet (which I know will clear this on most boards) this one password or passcode) seems to be unusually stubborn to clear. I know on most older DELL machines there was a seperate jumper for the password and am wondering if this is the case here?
Also, does anyone know where I can get a manual for this board?
Thanks,
Phoenix
(Darth Venom)
Who is the manufacturer of your motherboard and which BIOS does it use? I should be able to find a backdoor for the BIOS.
