Question about Whirlpool Duet GHW9150P Front Load Washer
Front door wont open we turned it off then on hit the pause and cancel cyle is there a manual way to open it
You might need to unplug it. Then plug it back in and try to unlock it by hitting the pause button.
Posted on Sep 28, 2010
MY FRIDGIDAIRE AFFINITY KEEPS PAUSING DURING CYLES DOSENT MATTER WHAT CYCLE I CHOOSE. IT STOPS ATLEAST 5 TIMES PER CYCLE AND SOMETIME WONT FINISH THE CYCLE. MODEL NUMBER FAFW3801LW3
Hi Brooke, thank you for allowing me to assist you!
Often this happens because the washer door is not securely latch or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, try reprogramming the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. If issue persists, then more than likely the unit has a faulty door latch, a communication error with the control board, or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Best regards!
Oct 30, 2013 | Frigidaire Affinity ATF7000E Front Load...
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Normal and heavy cyle lights wont come onwhen selected What is happening?
do you get 7 flashes of the clean light? if so, do this: Open door press: high temp, energy save, high temp, energy save, close door, open door, press cancel. then run as usual.
Jan 15, 2011 | KitchenAid 24 in. KUDP02FR Built-in...
Washing machine flashing FH and beeping
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put
everything back... this should fix the issue.
May 31, 2010 | Kenmore Washing Machines
Door wont open on my washing machine hoover select 1500
I just had the same problem and came here looking for a solution...I went back one last time and tried to unplug. That didn't work. Then I put it on drain/spin and after a minute interrupted by hitting the pause/cancel button - and it released! I am so happy!
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
F 26 Code that won't go away
The F26 error code on the Duet washer is a door switch error. The button inside the door opening might be stuck so that it doesn't register as being opened and closed. First press the pause/cancel button to clear the error display. Next push the button inside the door opening a few times and pull it so that it pops out completely. That should solve the problem.
Dec 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
175 people viewed this question
Dan Webster
Dan Webster
Sal De
