Question about Sport & Outdoor - Others
SOURCE: need to know flash relay position in fuse box diagram helpful
i need the 2003 ranger fuse box diagram can i get it for free? and where
Posted on Sep 17, 2008
SOURCE: i need a 2002 ford ranger fuse box diagram and afuel pump relay switch diagram
Hi
go to www.motorcraftservice.com then click on the owner guide and put in your truck information
then choose the 1st owner manual printing and should be between page # 184 to 200.
Good luck and I hope this will awnser your question.
Posted on Nov 08, 2008
SOURCE: need to know what fuse goes where
I am not sure if this right and there should be diagram on the back of cover.
1 5A Power Mirror Switch
2 10A Daytime Running Lights (DRL),
Back-up Lamps, Transmission,
Passenger Air Bag Deactivation
Switch, Blower Motor Relay
3 7.5A Right Stop/Turn Trailer Tow
Connector
4 — Not Used
5 15A 4x4 Control Module
6 — Not Used
7 7.5A Left Stop/Turn Trailer Tow
Connector
8 — Not Used
9 7.5A Brake Pedal Position Switch
10 7.5A Speed Control Servo/Amplifier
Assembly, Generic Electronic
Module (GEM), Shift Lock
Actuator, Turn Signals
11 7.5A Instrument Cluster, 4x4, Main
Light Switch, Truck Central
Security Module (TCSM)
12 — Not Used
13 20A Brake Pedal Position Switch
14 10A or Not Used 10A: If equipped with Anti-Lock
Brake System (ABS) Control
Module
15 — Not Used
16 30A Windshield Wiper Motor, Wiper
Hi-Lo Relay, Wiper Run/Park
Relay
17 20A Cigar Lighter, Data Link
Connector (DLC)
18 — Not Used
19 25A PCM Power Diode, Ignition, PATS
20 7.5A Generic Electronic Module
(GEM), Radio
21 15A Flasher (Hazard)
22 20A Auxiliary Power Socket
23 — Not Used
24 7.5A Clutch Pedal Position (CPP)
switch, Starter Interrupt Relay
25 — Not Used
26 10A Battery Saver Relay, Auxillary
Relay Box, Restraint Central
Module (RCM), Generic Electroic
Module (GEM), Instrument
Cluster
27 — Not Used
28 7.5A Generic Electronic Module
(GEM), Radio
29 20A Radio
30 — Not Used
31 — Not Used
32 — Not Used
33 15A Headlamps, Daytime Running
Lamps (DRL) Module, Instrument
Cluster
34 — Not Used
35 15A or Not Used 15A: Horn Relay if Not Equipped
with Truck Central Security
Module
36 — Not Used
Posted on Jun 02, 2009
SOURCE: Diagram of 1996 ford ranger fusebox which fuse is
RANGER FUSE PANEL
Fuse Position
Rating
Circuit Protected
7.5 Amp
Power Mirror
Not Used
15 Amp
Parking Lamps
10 Amp
Left Headlamp
5
10 Amp
On Board Diagnostic (OBD) II System
6
7.5 Amp
Air Bag System/Blower Relay
7
7.5 Amp
Illumination Switches
8
10 Amp
Right Headlamp/Fog Lamp System
9
10 Amp
ABS System
10
7.5 Amp
Speed Control/GEM System/Brake Interlock
11
7.5 Amp
Warning Lamps
12
10 Amp
Front Washer System
13
15 Amp
PCM System/Stoplamps/
4WD/ABS/Speed Control
14
10/20 Amp
ABS System
15
7.5 Amp
Air Bag System/Alternator
16
30 Amp
Front Wiper
17
15 Amp
Cigar Lighter
18
15 Amp
A/C System
19
25 Amp
Ignition Coil/PCM System
20
7.5 Amp
Radio/GEM System/Anti-Theft
21
15 Amp
Hazard Lamps
22
10 Amp
Turn Signals
23
Not Used
24
10 Amp
Starter Relay/Anti-Theft
25
7.5 Amp
Speedometer/GEM System
26
10 Amp
4R44E/4R55E Trans./Backup Lamps/DRL System
27
10 Amp
Underhood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/4x4 Sys.
28
7.5 Amp
GEM System
29
10 Amp
Audio System
30
Not Used
31
Not Used
32
Not Used
33
15 Amp
High Beam Lamps
34
Not Used
Posted on Mar 14, 2010
Feb 18, 2016 | Boating
Jan 05, 2016 | Boating
Nov 19, 2015 | Boating
Sep 02, 2014 | Boating
Jan 03, 2014 | 2003 Ford Ranger Regular Cab
Oct 20, 2012 | 2001 Ford Ranger Regular Cab
Nov 06, 2009 | Bass Pro Boating
Aug 04, 2008 | 2003 Ford Ranger Regular Cab
54 people viewed this question
