Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Audio works but not the video.
My unit is about 2 yrs old and one day the picture went out but the audio continued. I put dvds in and it will do the same.
  • 558 Answers
The thing about these consumer tv's is that they use the most grossly cheap electronic components in them so that they wear out quickly. the main power board is faulty, could e several small capacitors or a transformer , but a electronics service tech will need to do the work unless you have used a soldering iron and are comfortable with it. A replacement power board may be found on ebay for your model tv.
and last purchase a backup power supply to condition the electricity so that the tv will get smooth electricity from now on. hope this helps you . good day
Posted on May 28, 2008
Bought sony bravia 6 37" lcd hd tv 2 yrs ago +$1,500 when picture went dark, then out; srvc repair diagntc $75+tx. Now, we hv audio but only one channel wh cannot be seen & remot doesn't work. Were...
1,If you still have the old tv, reconnect.
2 turn on power after connecting cables making sure audio goes into ado and video into video.- very important.
3. do you get the pic, and sound?
4 if you do, do the settings to your choice.
will talk about new if the old does not work, good luck lindamilo.
Dec 25, 2013 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
My toshiba sdk990ku dvd player stopping playing the audio. Have connected via HDMI to LCD HD tv and worked for months! One day audio stopped, but picture is fine. Tried different HDMI cables, dvds with no...
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Nov 18, 2010 | Toshiba SDK990 Player
My car stereo quit working
Is the harness connected correctly and tight on the radio
Mar 21, 2010 | Dual Car Audio & Video
Will play dvds with sound fine...but no sound from tv
You have to connect extra red & white audio cable from your TV's (or cable box, if you have one) AUDIO OUT to the Home Theater's AUX IN 2 at the back (below Video In). Set the HTS unit to AUX 2 using the AUX button on the remote control and you should be able to get sound.
Jun 14, 2009 | Samsung HT-P38 System
Memorex 9' screen dvd unit mdv2009-want to send video to tv
found a manual and downloaded it-the unit was not designed to export video to another monitor
Dec 16, 2008 | Memorex Televison & Video
Audio only, no picture
Audio without video is usally a vertical or horizontal deflection problem with the DPTV chassis and Mag 1 chassis which is what you have. You may need a new deflection Large signal board. If you would like a link to one of those boards let me know.
Jul 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
NO PICTURE AND AUDIO IS DISPLAYING POWER LIGHT ONLY GLOWING
Hi
Rajesh, Now grundig tv,s Service Not Avail In India But It s
Not a Big Problem U can Call Good TV service Engrs. He Will
Solve Ur Problem
No_2........ Option Is U go for old grundig TV Dealer Or Retalers
Thay Can Help U
Regards
Manmohan Mohapatra
Nov 21, 2007 | Televison & Video
Televison & Video Logo
142 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
