Question about Garden
Kawasaki air compressor, 20 gallon, 3 HP, manual
  • 47 Answers
SOURCE: air compressor
could not find any such air compressor on the net. Please check the make and model and reply back.
Posted on Apr 01, 2008
SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Posted on Nov 26, 2008
  • 1383 Answers
SOURCE: Makita MAC 5200 3 HP 5.2 Gallon electric compressor
Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
Posted on Feb 23, 2009
  • 5 Answers
SOURCE: need wiring diagram for a kobalt 60 gallon 3.7 hp
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Posted on Jul 15, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
Posted on Jul 23, 2009
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Need to know wire size to wire.
12 GA
12/3
You should have instructions?
By Code a separate circuit and breaker-- 20 amp
Dec 21, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
1 HP 3 Gallon Air Compressor does not build up pressure.
it sounds like the regulator is out of whack turning down increases air pressure. make sure there is no leaks
Jun 28, 2009 | Air Tools & Compressors
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Garden Logo
253 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
