Question about RCA HD61LPW175 61" Rear Projection HDTV
I have HD61LPW175 and after watching for about 45 minutes the tv just shuts off. It then tries to turn itself back on but then the light blinks 5 times. The bulb has been replaced and it still happens. You have to wait about a three hours or so before the tv will turn back on again for about 10 minutes until it shuts itself off again. Any ideas?
  • 3 Answers
Sounds like a bad color wheel. Getting ready to replace my own. The bad problem here is finding a new color wheel as many are "no longer available".
Posted on Nov 28, 2010
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I turn on the tv it clicks a few times after I hear static, Then it shuts off by itself
try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Let me know what you find and I will tell you what it means.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 13, 2009 | Mitsubishi WS-65807 65" Rear Projection...
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Jvc av-48wp55 shutting off on its own
Is pix ok before shutdown?
If convergence is wildly misaligned then load may be shutting down power supply. Fix convergence and TV OK.
or
Poor solder connections on main chassis near FBTX and h drive. Needs expert solder work
easyab@hotmail.com
calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
Jun 14, 2008 | JVC AV-48WP30 48" Rear Projection...
TV won't turn on
There is a failure in the scan amplifiers, and or the power supply. This will require trouble shooting by an experienced TV tech who has access to the service manuals and know the set.
There are many components in the set that can cause this type of failure.
Did you not take an extended warranty???
This type of repair is not low in cost to have done.
Jerry G.
Jun 05, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Not turning on again
try cleaning The air filter in your set. It may be a thermal problem due to a clogged air filter.
Jan 19, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW175 61" Rear Projection HDTV Logo
146 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
