Question about Intermatic ET71615CR - 365-Day Electronic Astronomic Time Switch - NEMA 3R
Need diagram on how to wire et71615cr time clock
  • 56 Answers
Go to intermatic .com then enter your model nomber and you will be able to download and print your manual. Good luck!
Posted on Oct 02, 2010
Honda CBF 1000, '07. The time on the clock can't be kept on the memory.
That will happen if there is no power to the clock. I assume the battery is not flat as you can start it. My clock is always on, even without the ignition on and if I disconnect the battery it restarts at 1:00 am. I would check to see if there is power to the clock with no ignition and the wire is not broken in the loom somewhere. I say this because power is obviously getting through when switched on. You will need a wiring diagram for your bike. It is possible it may be connected via an "auxilliary circuit".
Jul 20, 2015 | Motorcycles
Need wiring diagram
try the brake switch adjustment located at top of brake pedal turns anti and clock wise disconnect the wire first clockwise if lights not coming on anti clock if lights are on all the time ,i don't know if this was your problem let me know if this was of any help
May 05, 2014 | 1998 Chevrolet Chevrolet silverado
How do I connect my Jandy AE-TI heat pump to my intermatic T104P3
1) Copy following link for wiring illustration ... assuming timer is supposed to control pool pump:
http://waterheatertimer.org/images/T104-to-contactor.jpg
2) T104P is 240Volt (208-277V) SPDT timer in P plastic outdoor enclosure.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Jandy AE-TI is 208/230V pool heater.
http://www.bestbuypoolsupply.com/media/aemanual.pdf
4) Page 13 of Jandy manual shows single-phase residential wiring diagram.
5) First of all, power to main contactor is not interruped by timer, since this powers 24Volt transformer that controls the chip board and general operation.
6) The timer is connected to 'Auto-heat contactor.'
The confusion is what Load connects to this contactor? The water pump? Load is shown on diagram as 'pump time clock.'
I assume the load is the PUMP??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 04, 2012 | Hardware & Accessories
I NEED A SIDE DOOR WIRING DIAGRAM FOR A2005 BUICK TERRAZA
I had to cut the retracting wire for opening the door as it got jammed could not close door without chime going all of the time . I removed the fuse which solved the noise problem except now my radio and clock will not work . I know the chime goes through the speakers . How can I disconnect the wire from the door and put the fuse back in the get my radio and clock working . I do not plan to replace the retraction wire for the automatic door
Jan 29, 2012 | Buick Terraza Cars & Trucks
Need wiring diagram for T104M 208-277v Mech. Time Time Switch
Here is the basic instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Below is a larger and better diagram of a 240V connection Terminal connections are White to White on 3 & 4 Black to Black on 1 & 2:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
More info: http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
I am assuming you have the 240 VAC clock motor so the clock timer motor wires are connected to terminals 1 and 3.
If you only have the 120 VAC clock motor the wires will be connected across terminals 1 and 2.
Thanks for choosing FixYa,
Kelly
Jun 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
I need plug wire diagram for a 1975 olds cutlass 455 eng.
I'm afraid I can't send you a diagram but I see nobody else has sent you one either. So here goes. Your odd numbered cylinders, 1-3-5-7 are on the driver's side front to back. Your even numbered cylinders, 2-4-6-8 are on the pasenger side front to back.
Your distributor cap should have 4 hold down screws placed at 2 o'clock, 5 o'clock, 8 o'clock and 11 o'clock. Your number 1 cylinder is the first plug tower toward the firewall (or behind) the 2 o'clock hold down screw.The distributor runs counter clockwise or backwards and the firing order is 1-8-4-3-6-5-7-2.
Your timing depends on which model you have. All models except Tornado are timed at 16 degrees before TDC. The Tornado is timed at 12 degrees. The timing also is set with the engine running at 1100 RPM not the traditional idle speed. Hope this helps.
May 20, 2011 | Oldsmobile Cutlass Supreme Cars & Trucks
How to install a Hydro king 2 circuit time swith (model t101p201) a pool clock. we can get it to turn on the pump but the clock does not rotate.
You should have a wiring diagram on the cover of the timer. I believe that behnid the terminals where the 2 supply wires are connected are 2 white wires that supply power to the clock mechanism. If these 2 white wired are actually connected to the back of the incoming power terminals and the clock is still not keeping time, the clock may be faulty.
Gary
Dec 21, 2010 | Garden
I want to wire a photocell to overide my T101 timer for cloudy overcast days. Please provide a wiring diagram. Thank you
You need to come off the line side of the clock to feed your photocell. And then from the load side of the photocell you can feed to the load side of the time clock. Leave the time clock wired the way it is now. What this will do is feed the light with the photocell or the time clock, but keep in mind by doing this the light will always remain on when it is dark. There is no other way to do it.
Sep 30, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I replaced my pool clock ( Intermatic)twice. still
I have the same problem with the t104 clock. wired exactly to the diagram. this is the second one, the first one i thought it was a defective timer so i replaced it with another t104 and also wired it exactly to the diagram and still nothing. am i not doing something right???? line 1 to 1, line 2 to 3.....
Mar 30, 2010 | Intermatic T104 24h 208-277v Mechanical...
Need wiring diagram for Hayward dual Super 2 speed pump. Old unit had 3 wires and new unit has 5 wires.
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
Aug 29, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Intermatic ET71615CR - 365-Day Electronic Astronomic Time Switch - NEMA 3R Logo
66 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
