Question about Samsung Televison & Video
I just bought a samsung DVD-R155, and connected my vcr to this unit through the front av jacks. I have copied about 8 movies. Last night I tried to watch one on my computer, and it does not work, out of the 10 I copied, 2 have problems on my computer, but not on 2 other dvd players. I opened the files on the dvd and found the the 2 that do not work have 3 files on them, the ones the work fine on my computer have only 1. It appears to me that the finalization process is not working. any ideas, before i call samsung? Thanks. John
Go to samsung.com and search for your model DVD-R155 and read the FAQ section. Someone has posted this question and the response is YES you can copy VHS files. I had one experience trying to do this and had the same experience but was only trying to see if I could. I'm thinking that possibly the answer is to enter the MENU and de-select automatically create chapters. I don't think there is anything wrong with your recorder.
Posted on Oct 26, 2008
Re v5500 . . . can i copy a movie from the vcr onto a dvd with this model???
You cannot transfer VHS to DVD on this model unit by itself. You can, however, connect the AV outputs of this unit (as a VCR) to the respective AV inputs of a separate DVD recorder - using yellow-white-red RCA cables - as long as the source tapes are not copy protected, and the appropriate disc formats for the DVD recorder are used.
Apr 20, 2011 | Samsung DVD-V5500 DVD Player/VCR
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
I can't record a DVD from VCR. I tried hooking straight to front av jacks,no luck. I have dish network it's set on channel 25,video 1 on the tv. No problem recording from dish,just can't get it to record...
You need to select front AV as you video source on the DVD recorder if using the front AV phono connectors. Make sure the lead you use from the VCR is working y connecting the AV leads directly to your TV if possible.
Mar 03, 2011 | Philips Magnavox MWR10D6 DVD Recorder
TRYING TO COPY VIDEO TO DVD Only records in black and white ????
Store bought tapes with movie release have a copy guard protector imprinted in the tape preventing successful dubbing, especially the more recent movies.
Jan 06, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Code for unlocking dvd regions samsung r155
hi,
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
Thank u
Oct 07, 2009 | Samsung DVD-R155
How to connect my dvr with cable tv
I Do believe that Foxtel puts a block on movies so you cannot copy them..
Mar 30, 2008 | Samsung DVD-R155
Does the DVD-R155 create PC compatible DVDs?
just try to load the dvd disc.and see if it is reading..
Feb 04, 2008 | Samsung DVD-R155
Samsung DVD-VR357 Won't play ANY DVD's
I have the same problem. How do you reset the unit?
Jan 09, 2008 | Samsung DVD-VR357
Camcorder connect to Insignia dvd/vhs copier unit
connect to front press av input button. set it on av 2. make sure your tv input is set to v2-component.
Dec 24, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Changing input jacks
has your remote control got a AV button on if so then press this till AV 3 if your video has 2 scarts at back and av jacks in front if your remote has not got AV button press the ch- key till you see AV3 on desplay. If you still have the user manual refer to this. hope all goes well
Aug 20, 2007 | Emerson EWD2204 DVD Player/VCR
Televison & Video Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
