Question about SanDisk ULTRA II 4GB Compact Flash Card Flash
CF cards stopped working
Twice this has happened, once with SanDisk Ultra II 8GB and once withExtreme III 4GB. My camera is a Canon 5D.
I shot a load of pictures, took the CF card out and inserted it into the slot in my computer. In the case of the 4GB, I downloaded the pics and put the disc back into the camera to format. The camera says CF card not formatted. I tried formatting it with the computer but the computed just says "duh-there's nothing here!"
The 8GB just happened yesterday. The computer didn't even recognize it to download. Back in the camera - same message.
  • 2 more comments
  • gbuzzell May 24, 2008
    Thanks dilipbagdi, but NEITHER the camera nor the computer recognize the card. Except for the once (and in despiration) I have never tried to use the computer to format a card.
    This lack of recognition happened spontaneously. Suddenly, and for no reason I can tell, the card went silent.
    Cheers, Jerry
  • gbuzzell May 26, 2008
    Dear Dilipbagdi,
    I managed to find a card reader and computer which would recognize the cards and allowed me to download the missing pics from the 8GB card. Then I reformatted them using FAT32. Result - nada! Camera still doesn't recognize that the card is formatted and refuses to format the card itself.
    Cheers, Jerry
    Dear Bestdarngood,
    Thank you for your suggestion. I haven't been able to track down the Microtech card reader yet but I'll go searching tonight. Al Ain is a bit of a backwater; I'm hoping I don't have to go to Dubai or Abu Dhabi to find it.
    I'll let you know when and if I get things working. I did manage to get the cards recognized on my computer with a Sandisc ImageMate reader so I could get my pics off. Tried reformatting and it didn't work.
    Thanks for the advice. I'll keep you posted.
    Cheers, Jerry
    Dear Jaimie867,
    Cheers, Jerry
    Scholar:
  • 137 Answers
Post 4 , bad advice, read page 83 in the Fuji S602 manual.
Posted on Jun 01, 2010
    President:
  • 1,257 Answers
Hello friend
Actually the problem is with the file system ,there is no problem with your card and computer ,you must keep in mind that what file system is used by your device i.e either camera or any other device ,as far as possible all the device uses FAT file system..to know this in MY COMPUTER > Right Click the Card and select properties > there you will see the file system option and next to it will your card file system .so if you want to format a card ,just format it in your device if you get the option to format the card ,so if the device formats it , it will format it with the file system it supports ..but if you are unable just attach it with your pc .right click on that and select properties than you will come to know about file system...now to format it in pc right click on it and select format > a box will appear there you will get optiio to select filesystem .select the file system that is supported by your camera and format it ................................
Thanks and Regard
dilipbagdi
Technical Associate
Posted on May 24, 2008
  • 3,037 Answers
Buy or borrow one of Zio or CameraMate card readers from Microtech (http://www.microtechint.com) with latest driver and format your card in the reader. The name of file is SMPREP.EXE for SM card and CFPREP.EXE for CF card. Once the driver is installed the program will start automatically when you start to format a card in the reader through Windows Explorer. After the format, insert the card into the camera and turn the switch on. The camera should recognize the card.
I've seen a 64MB SM card started to work again this way after it was accidentally formated with Windows Exlorer which was using a PCMCIA adapter. The card was not recognized in the camera or CameraMate reader with older driver. The card in PCMCIA adapter woked fine for copying, deleting and reading files though.
I believe Windows formats cards in 32 bit while the camera formats in 12 bit.
That is why you need to format the card with special FORMAT software once you used the card in the computer and want to use it in the digital camera.
At the moment the Microtech card reader with their latest driver is the only product I know of that can format SM and CF cards outside of the camera.
Someone else may know about the products from the other manufacturers which will format SM and CF cards and you can use them in the camera.
Please let me know if you have any further questions or need any more help as I would be glad to do what I can.
good luck
  • Benjamin Patri
    Benjamin Patri May 24, 2008
    Hi Jerry, Since you only responded to the first solution, I'm wondering if you saw mine which is the only one that will work with your specific situation since nothing recognizes this card.
  • Benjamin Patri
    Benjamin Patri May 27, 2008
    You could try this.....leave the card out of the camera and turn it on,
    you should get a message to insert a card.....turn the camera off and
    insert your card....if you get the format card box appear, try it via
    the setup in your menu rather than pressing yes, if that's what
    appears....if that doesn't work, if you know someone with a camera that
    takes sd cards, my D80 does, see if the card can be formatted in
    another camera, then try it in yours, if you get no error, then
    reformat the card in your camera...you should always format cards in
    the camera to avoid any issues.....also check that the card is not locked just in case, check the tab on the side of the card to ensure that it isn't
    let me know how this goes
  • 813 Answers
Hi friend
make shoure your cam supports dvd -r or +r your dvd is rewitable if not then u cant do anyting
  • 2,334 Answers
You should try to format it to FAT32 not FAT only.
I shot 200 pics w/Canon EOS rebel XT 8mp camera on a new San Disk Ultra 4GB card. All pics look like flash did not work. It was working and I've shot hundreds of pics in same place, same lighting, using...
The CF card has nothing to do with the information that is sent to it. It is just a recordable medium that stores what the camera sends to it. There is some other problem with the settings of the camera that caused the photos to be underexposed. Do you use RAW mode for capture of the images? If you do then the Canon RAW conversion software can batch process the photos to correct the exposure.
Apr 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
Sandisk extreme III says CF full when the card is empty
If you've tried the usual fixes like reformatting the card and trying it out in other cameras, then there is nothing more you can do to fix this.
Fortunately, Sandisk are very good at replacing faulty memory cards provided they've not suffered physical damage. Just contact the company to find out how to exchange your CF card.
Nov 06, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Can I use a 4GB CompactFlash in my 5700 Nikon
According to Nikon it only supports up to 1GB CF cards, but as I suspected it had never been tested by them with larger CF cards (they weren't available above 500MB when the camera was released) I tried 2GB cards from various manufacturers and confirmed that they do not work.
I found that the best and most reliable performance with this particular Coolpix was with Sandisk Ultra cards. Ultra II (and above) offered no performance advantage with the camera itself, but if you use Ultra II then you will get speedier file transfers when using an external card reader. The camera will work with Ultra III but the camera writes noticeably slower to third generation Ultras than it does to the earlier versions.
The camera is no longer supported by Nikon and no firmware updates were ever released to extend CF capability.
Oct 12, 2009 | Nikon Cameras
Card reader in camera or computor wont read sdhc cards
Although my SanDisk compactFlash cards 128 MB 256MB 4GB and 8GB cards are far from being full, when I open up my Canon Powershot A40, the follwing msg appears: CF card full. However, the original Canon Compactflash card FC 8M provided with my camera will still accept new photos. The problem is recent. Can someone help me.
Sep 13, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Sandisk ext'me IV 8GB cf card states 'card error' in olympus e410
Please format the CF card in your computer with an external cardreader on full format and probly your card is working on an Olympus E410
Mar 08, 2009 | Olympus EVOLT E-410 Digital Camera
Can't initialize SanDisk Ultra II for S7000
try formatting it in the computer, then initializing it in the camera.
It's possible that the camera can only handle memory up to 1Gb. Try a 1g CF card.
Jan 01, 2009 | Sony Alpha DSLR-A200K Digital Camera
It looks as though the camera cannot support memory as high as 4GB. Capacities above 2.2 GB require that your camera supports "FAT32", and S7000 does not support FAT32.
Dec 30, 2008 | Fuji FinePix S7000 Digital Camera
Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Jan 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
SD card not registering
use only the specified or recommended cf cards, I know ultra fast is not compatible to digicam two or more years older models.
Oct 10, 2007 | Canon EOS-1Ds Mark II Digital Camera
SanDisk ULTRA II 4GB Compact Flash Card Flash Logo
324 people viewed this question
Top SanDisk Cameras Experts
Henry
Nikki  Mclean
Nikki Mclean
Are you a SanDisk Camera Expert? Answer questions, earn points and help others
