Question about Sharp LC42SB45U 42 in. LCD TV
My sharp lcd tv keeps changing input by itself
  • 130 Answers
Hi
first be sure that your cables are all contact solid
your problem is that the tv do not recognize any signal and it keep on scanning to find one.
Posted on Sep 28, 2010
  • 2 more comments
  • cyberwisdom Mar 19, 2011
    Did this fix your problem? I'm having the same issue and have disconnected everything, but it keeps switching inputs by itself. It happens randomly. Does anyone have another solution?
  • Hari Shankar Sep 24, 2011
    This doesn't help. I have been having this issue for the past 8 months or so. I was even thinking of removing the panel (that contains the channel, volume, and power buttons) at the back on the right bottom, and checking the things. But, did not have enough time to spend on this. Anyone has similar problems and has been able to get it resolved?
  • Evette J Oct 25, 2012
    I have the same issue with my Sharp TV. It just started out of the blue. The TV is only about 3-4 years old.
  • krazzieguy24
    krazzieguy24 Nov 20, 2012
    I have the same problem with my LC42SB45U. I have notice soon as I plug it to the wall outlet the tv turns on automatically. After a few minutes the input comes up and constantly scrolls through the input menu. I have called sharp with this issue and all they said was to take it to a repair show. I am trying to fix this on my own and it seems I can not find a solution to this problem.
I have a Sharp LCD that keeps changing inputs and will randomly turn itself on.
Sounds like you have another infared source that the LCD is seeing. Put opaque tape over the infared receiver and see if the issue continues. Look for another IR device in the area.
Nov 09, 2014 | Sharp Televison & Video
How to change pc mode of sharp into tv mode
Use the input selector to change back to TV. Usually the first input on the list.
Jun 26, 2014 | Sharp LC-32SB24U 32 in. LCD TV
2 problem with my lcd
Could be the button board which has power and input buttons. If they are stuck down or failing electronically they could be telling your TV to continuously turn off or change inputs.
Mar 03, 2014 | Sharp Televison & Video
Sharp tv keeps changing the source channel on its own
you may fave a faulty switch in the key controller, may best advice is replace it
Part numbers:
KC792
XC792WJ
Fred
Jun 18, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have a Sharp LCD TV and a Toshiba Satelite laptop. I have never had any problems connecting my laptop to the tv using a vga cable. It isn't working anymore however. I checked the cables and...
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Jun 11, 2009 | Sharp LC-32D64U LCD TV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Channel keeps changing to 'Input 2' even when playing DVD
Have you taken the remote control out of the room? Try changing inputs from the TV.
Dec 21, 2008 | Sharp 32F641 TV
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp tv changing channels
Well, the only thing that seems to be working so far is to plug AV cables into the "input 2" ports (on the front of TV). I plugged in my PS2, without turning it on. It has not switched at random since (about 30 minutes - it had been switching off and on for the past 2 hours). Anyone else have similar success?
Oct 28, 2006 | Sharp 32F540 32" TV
Sharp LC42SB45U 42 in. LCD TV Logo
1,113 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
