Question about GE Monogram Side by Side Refrigerator
I have a GE ZISS360DRJSS side by side fridge. The water is not dispensing from the door. It makes ice without any issues. I changed the water filter which did not help. I turned off the entire fridge/freezer overnight in case it was frozen water line, the same problem remains. Also, frost forms in the ice dispensing chute. I believe there is a flap that is supposed to close when the ice dispenser is not in use to keep the cold in/warm out, this is not closingr. Any ideas how to fix these two problems?
  • 4,070 Answers
They could be related with the open door allowing the line to freeze.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don't hear it there is a dispenser actuator switch problem.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here is a link to a diagram which may help.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-ZISS360DRJSS/0432/0165000/G0705134/00001?blt=06&prst=&shdMod=
Posted on Sep 28, 2010
Ice and Water dispenser is inoperable.
I had a GE Fridge at one time and had issues like yours.
If you disconnected the connector at the door that supplies the dispenser with power, you would not measure any voltage on the dispenser side, only on the 'fridge' side. Measure the power with the connector connected, but that may not tell you a lot, unless you have the service manual.
If you push the water dispenser and you do not hear the little valve kick on behind the fridge, suspect a couple of things. A faulty inlet valve (usually located lower rear of fridge on backside). It may be disconnected. Had this happen once on a new fridge - it had been disconnected from the factory.
You may have one problem or two issues, but let's continue...
Do you push the ice dispensor and nothing happens? Or are you telling us that the dispenser works but there is no ice? The faulty valve mentioned above will prevent ice dispenser from filling to make ice.
Also, there is RESET button hidden in the freezer a well. I can't remember where it is but the little arm to make ice has to be in position to tell it to make ice, and you have to follow the procedure in yourf ridge manual to reset it. It's
Another problem I encountered, but this was just with the cold water dispenser, was that the water line would FREEZE in the fridge door, preventing water from getting to the dispenser and my cup. It wold make ice but no water. In that case I had to get a small squirt bottle with a long nose on it and shoot hot water up into the dispenser nozzle to clear the ice in the line. That only happened a couple tines a year, though.
Here's a video that may help: https://www.youtube.com/watch?v=fPeZ29XdX5U
Sep 05, 2015 | GE Monogram ZISS480DRSS Stainless Steel
Fridge will not dispense water door.but will dispense Ice
There are a couple of things that could cause this issue, the easiest and cheapest of the two would be the water filter, they are to be changed out each year, or at yearly intervals. The other would be the water solenoid valve.
Mar 10, 2011 | GE GSH25SGPSS Side by Side Refrigerator
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Water Dispenser leaks from rear of fridge
the answer to the problem is behind that back panel.
Nov 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25L GE no water
Check the electrical connector that is next to the water pipe at the bottom of the freezer door
Aug 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Model TFF24RWC Side By Side Ice/Water not Dispensing
I had that issue and a myriad of other issues with my GE side by side fridge. I replaced the control panel $100 and all three problems I had went away immediately.
1. Ice and water dispenser quit working
2. Howling noise 12 hours out of the day
3. Clicking noise
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram Side by Side Refrigerator Logo
157 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
