Question about Panasonic NN-P294WF Microwave Oven
Stop after 5 seconds
My microwave oven stops after around 4-5 seconds, and the clock went off, but not totally gone, the middle two dots are still visible on the clock panel. I can still schedule time and start the microwave oven. But it will stop in seconds.
  • Panasonic Master
  • 9,098 Answers
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
I have a 18mth old Panasonic dimensions 4 invertor microwave oven that turns on for 3 or 4 seconds and stops altogether,any ideas?
What does the clock say after it stops? Is the time still correct, or is it wrong? Or maybe you mean only the turntable stops spinning, in which case the problem may just be that it needs a new belt! Try RepairClinic.com if that is the case!
May 16, 2017 | Panasonic Microwave Ovens
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
Microwave won't set clock
It is most likely the keypad control board has been damaged, first! unplug the microwave oven for 5 minutes, if this works the micopressor will reset, if it fails the control board will need to be replaced, a costly venture.
Apr 14, 2012 | Danby DMW1153 Microwave Oven
Microwave stop working
my microwave oven just stopped heating giving me a f9 error .lights are on clock is working and the panel is ok.
Jun 15, 2010 | GE Profile Spacemaker Over-the-Range...
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Cycle stops and won't run until the clock is reset
The magnetron cooling fan blade is either slipping on the motor shaft or has spun and fallen completely off the shaft. It can be reattached to the shaft as it just slides on. Several well placed drops of 5 minute two-part epoxy from Home Depot or Lowe's dripped into the hole in the fan blade before you slide it back on will insure that it doesn't come off again
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Oct 03, 2007 | GE JVM1650 1000 Watts Microwave Oven
Panasonic NN-P294WF Microwave Oven Logo
132 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
