Question about Goodman Heating & Cooling
Purchased Goodman 5 ton unit in 2007. The problem we are having is: When you turn the unit on and set it at 76deg. the temp states on the controller it set at 81 deg in the house, BUT it would not cool enough to bring the house temp up to 78deg. the unit stayed on all evening, and remained at 86 deg without ever shutting off.... I know thta is going to hurt at bill time. Any help you can provide would be appreiated..... My email address is: drsduvall@aol.com
  • 828 Answers
Your system could have lost its refrigerant charge through a leak. Check for visual signs of oil at any soldered joints. This would indicate a leak at a point where some oil is visible. Also check for frost on the big line that returns to the outside unit. If frost is present set you air circulation fan to the on position and turn the cooling to off. Allow the air to circulate for about an hour. Then return the system to the cooling mode. Operate the system when cooling with the fan in the on position in this case.
Posted on May 24, 2008
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
How many tons is a Goodman Central Air Unit with Model Number CKL30-IE?
That is a 2.5 ton system. The model numbers are as indicated:
24- 2 ton.
30- 2.5 ton.
36- 3 ton.
42- 3.5 ton.
48- 4 ton.
60- 5 ton.
Hope this answers your question!
Jul 15, 2010 | Goodman CKL60AR60 Air Conditioner
Its gets up to100 during the day here right now. my ac is set on 78 and comes on at noon and does not turn off till at least midnite. the temp on the thermostat stays at 80 untill after midnite. ...
Check the outdoor unit you should have hot air discharging out the top of the condensor. The insulated suction line should be sweating. The inside
coile should be condensating and water should be flowing to a drain from the indoor unit.
If all of that is happening, then I would say you now
have a ubdersized unit. If none of that is happening
then I would say you are low on refrigerant.
Jun 24, 2010 | Goodman CLJ30AR32 Air Conditioner
AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
May 27, 2010 | Goodman CLQ36AR49 Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Keepe shutting down the heat.
Mark is right 5 tons is way too big and you are probably icing up. Even here in Az we size units to no less than 500 sq. ft. per ton and more like 700 sq. ft. per ton. What is the make and model number of your unit? I'm a Goodman Authorized Contractor so I should have most info on hand.
Feb 13, 2009 | Goodman Heating & Cooling
5 ton goodman ac unit
You MUST WEIGH IN THE NEW CHARGE OF R-22. There should be a label on the side of the a/c unit that states what the factory charge was. This is only a starting point. Once you have the factory charge in the system, then turn on the unit and allow it to stabilize (5 min) . Check pressure on low side and check teperature on low side pipe. Temperature of pipe should be 8 to 15 degrees above what the boiling point of the refrigerant is for the current pressure you are reading. If the temperature is more than 15 degrees, add R-22 in 4oz increments allowing 5min in between each time you add until you are in the "zone". When you do this, your head pressure needs to be 225-250. if you need to cover the coil or block the outdoor fan to do this then do it. Hook up the vacuum pump and start over
Jun 17, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
