When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle
switch on the back. Hold down the 'eject' button and turn the toggle
switch back from off to on. This will run a fan test and should eject
your disc. Remember, this will only work on the 20, 40g models. Not
the backwards compatible units with the 4 usb port holes and the
memory card slots.
