Question about Mitsubishi WT-46809 46" Rear Projection Television
The TV was working great yesterday, but today, when you press the power button, th TV clicks on, then within 5 seconds clicks off, picture never appears but green light comes on until TV clicks off. Model is WT-46809
  • dreese615 Sep 30, 2010
    What does the repeating code of two blinks, then one blink mean. Is there a part number or picture of whre the part is that needs replaced.
  • SD Tech
    SD Tech Oct 30, 2012
    THE error codes are not part specific--2,1 is X-ray protection---means the High voltage to the 3 picture tubes the set uses is going too high--excessive high voltage and the tubes start to produce X-ray radiation---before we continue (if you want) I suggest you unplug the set for a short time and plug it back in and try to turn on again--do the self check again to confirm the error code is 2 blinks and one blink for 5 times---easy to misread it the first time--also what skill level do you have? I never know that unless I ask. If you have a volt meter and time I can help you. I know for example online where I can get for free the full service manual with diagrams etc. Keep in mind I do this here on FIXYA FOR FREE.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
SD TECH
Posted on Sep 28, 2010
Testimonial: "The light blinked two times, then 1 time then repeated."
  • 4 more comments
  • SD Tech
    SD Tech Sep 30, 2010
    You can unplug set and plug back in and double check--this will clear error buffer.
    2,1 is X-ray protection---it means a problem in High Voltage circuit of set, usually it means too high a voltage is being developed.
    There is one other thing you may want to do a visual look at, It is called Glycol. You know about this issue this and other Mitsubishi sets have?
    SD TECH
    Not sure what you mean by last paragraph...There is one other thing you may want to do a visual look at, It is called Glycol. You know about this issue this and other Mitsubishi sets have?
  • SD Tech
    YES, I am about to go offline.
    Glycol is a liquid used to cool each of the three picture tubes this set uses. These sets have a history of it leaking onto the circuit boards. I will return here tomorrow after noon Pacific time and explain to you.
    SD TECH
  • mcspooky Dec 01, 2011
    Having same problem. My tv blinked once then twice. What does this mean
  • Brian Oct 04, 2012
    I realize this post is pretty outdated now -- but was there a solution or any additional information to share? I am having this same issue?
  • pato_500
    pato_500 Oct 30, 2012
    I have error code 1-2 Could you help me please?
Top half of picture is black
How to access the self-check screen to reset the unit.
Select a television channel, and while pressing the [VOLUME ( - )] button on the main unit, press the [OK] button on the remote control for more than 3 seconds.
How to Exit the self-check screen
Press and hold the Power button on the TV for 5 seconds or disconnect the AC cord from the wall outlet
Jan 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have my PS3 plugged into my tv with an HDMI cable, and it was wroking fine just yesterday. But today I moved it back to my living room tv where it usually is but nothing shows up. It just says...
Please do the following to reset your display -
1. Turn the PS3 off into standby mode (red light on)
2. Press and hold the power button for 2 beeps (the first beep will be when you first press the button and the second beep will be around 5 seconds later)
3. Release the power button after you hear the second beep
4. Wait for the display to restart
Hope this helps and thank you for using FixYa
Jan 13, 2011 | Video Game Consoles & Games
Hi I have a brand new 320 GB PS3, barely a month old. Worked up until today when all I'm getting is "no signal". I've tried using other HDMI leads (component also) and TV's (mine is a Samsung...
Try these steps first -
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button when you hear this second beep
Wait for the PS3 to reset its display.
This will now choose the best setting for your TV and everything should be ok.
If you still get problems, go back to where you purchased it from or contact Sony, as it is under a year old it is still within warranty laws etc
Hope this helps
Nov 06, 2010 | Sony Playstation 3 (PS3) Console
Yesterday, our 61 inch panasonic projection tv showed pink colors on the lighter colors in the picture. This morning it has two large black stripes across the picture. What could this be? We changed the...
You may have not reset the lamp counter after replacing the physical lamp. To do this 1. Press the “POWER” button so that the projector projects the picture on the wall (projection screen)
2. Press the “MENU” button to show the “MAIN MENU”
Use buttons “F” or “G” and select “OPTION”
3. Confirm this by pressing “ENTER” so that “OPTION” is shown
Using buttons “5 / 6”, select “LAMP RUNTIME” (lamp operation counter)
4. Select and press the “ENTER” button for at least 3 seconds
5. The “LAMP RUNTIME” (lamp operation counter) will change to “TIME RESET[POWER OFF]”
6. Turn the device off by pressing “POWER” and unplug the power cord
Sep 09, 2010 | Panasonic Televison & Video
Picture stays on black
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Samsung tv le37r8
Using a monitor
1..connect computer/media center to your monitor,
2 click on nvidia nview display settings,
3, select the current display tab and samsung,
4 then apply,
5,then when the confirmation box appears click yes within 15 seconds.
Using your samsung.
Attach a scart to your media centre, from your t.v with the p.c cable still attached, turn over using the source button until you can see a pc picture on your screen (EXT1or2), do steps 2 & 3 THEN move your cursor to the apply button (do not move the cursor from this position), press your source button till you get PC channel (which has no picture yet) then press your mouse button to apply, ( your picture will flicker on), and before the picture goes confirm with the yes button. You now have light! eureka :)
Jan 01, 2008 | Televison & Video
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
No picture
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
Dec 05, 2007 | Mitsubishi WS-55807 TV
Sound, but no picture
Had the same thing today. Iwas playing with the auto demonstration of on screen displays. Press and hold the power button (5 seconds) on the TV. The auto display will play. Press the power button again (TV will go off). Turn power on again. you should now have the picture back
Nov 14, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Mitsubishi WT-46809 46" Rear Projection Television Logo
672 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
