Question about Kenmore Kitchen Ranges
I got F90 Err on my Kenmore range model 790.3103 when I try to use selfcleaning.
  • wendyliu_ny Sep 28, 2010
    Hi, Kapishtech:
    I disconneted the power for more than half hour but the problem is till there. I do not know where is the oven door light switch and also I realize when the signal of door closed, actually the door is open. Hope you can help me further. Thank you.
    Wendy
  • 2,272 Answers
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure.
To know more about the error.Please click the link directly:--
http://media.fotki.com/1_p,wkfqbqgbfsttgkkxgtqsskgwtqkq,vi/krbbqbrwbxksgbkrfss/1/1303472/5961857/image2335img-or.jpg
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 28, 2010
  • raj somaiya
    raj somaiya Sep 28, 2010
    Check the door latch which close and open.when you close the door or when you open the door.the latch is in the door.And latch gets connected to door frame on the oven.Is the latch in the door moving manually when you push it.Or is it looking cracked.Now with the door open.See to the over frame where the door latch connects.The area where door connects and gets locked.see to that area and see.If any thing got stuck up .Insert a minute screw driver in that over door frame area.Not in the door.In the oven frame where door connects.Then close the door.If still the same problem then door lock assembly in the oven frame has to be removed out and checked.Also it can be loose or short door connection.or over door frame assembly is faulty.
    Click this link for more help:---
    http://media.fotki.com/1_p,srkrwkqgswfkr...
    If this does not help I recommend replacing the complete door lock assembly part number; 318261221 $23.89 www.searspartsdirect.com
    Thanks for keeping updated with your query.
Started to bake an item, so I preheated the oven and started to cook item when all of a sudden an error code came up and stopped the oven from baking any longer. THE CODE( F95 ERR) came up and shut the...
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 23, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
My Kenmore Elite gas range is beeping and flashing F90, the door is locked. What can I do to clear this?
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^#$%
Aug 28, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Door lock indicator lit up but did not try to lock door. F90 err. After unplugging it for over 5 min and plugging it back in the door is still locked and will not unlock.
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jul 12, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
CODE F90
I have the same problem. my model number is Kenmore 970-556322. the whole stove is not working.
Oven door is not locked but got the message "door locked" on the control panel and won't allow reset via clear/off. and it shows F11 and F90 on the display, and the machine keep on beeping the whole day, tried to unplug and restart it next day, but didn't work.
Please help!
Jan 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
F90 Err on Kenmore Elite Gas Range 790.3670 How do I get rid of the error?
the F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board. It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Good Luck
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
What does the errror code F90 mean?
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore model# 790 94463700 serial# VF 735 37589
unplug the range.
wait 1 minute.
wait 2 minutes.
Aug 23, 2008 | Kenmore 96212 / 96214 / 96219 Electric...
Self Cleaning
unplug the range.
wait 1 minute.
wait 2 minutes.
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
Kenmore gas range trouble
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
230 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
