Question about Maytag Atlantis MDE7400AY Electric Dryer
In the back of the drier there is a wiring plastic looking block with a number of wires going into it. As you?re facing the back of the drier looking at that block the terminal on the far left has three wires going into it. Two of those wires are broken off. It looks like they may have touched and shorted out. The drier works but it doesn?t get hot. When I tried to remove the nut holding those wires on the stud into the block broke off. I think this block is going to have to be replaced. There was some heat and scorching going on back there, I think this must have happened when those two wires shorted out. The model number of the drier is MDE7400AYW and the ser. # is 24529865EJ. Can that block be replaced and the wires re-attached fairly easily or is it more of a job than what it looks like. Also in this case what parts should be replaced and what is the cost of those parts.
  • Maytag Master
  • 43,501 Answers
Often the vibration will loosen the wires, they then become hot and burn off...the block can be replaced... if you cannot buy it from and appliance repair site then check a local electrical supply. It really should not be that hard to replace it...
The burnt wires will need to be cut back and reattached...
You may even want to buy a new cord and use that to reattach to the block...
Here is a tip that will help you with changing your dryerplug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Sep 28, 2010
How to set timing for 97 chevy 7.4 454ss vin j ?
yuo need to look at the passenger side firewall and look for a black cover box against the forewall with 3 black long lug nuts looking things there plastic as well remove them and you will find wire connector if not remove the negative battery cable from the post on the battery and do it this way now to do this properly here are my steps ! My Name is Bobby im A Vo-Tec tech mechanic from NewYork . I have great news for you so please listen up just incase you still can not fire up your engine i will give you these simple instruction that no one will give to you out there ok . First reset your timing with number one piston all the way up at top dead center on the compression stroke by taking out the number one spark plug and take a 1/4 inch peace of stick with a plastic bag over it and wrapped real tight and stick it into the plug hole where its snuged fit in to the spark plug hole now using your ignition key to click the engine over little by little until you hear a blast pop sound that will be the stick with the plastic popping out of the # 1 cyclinder spark plug hole now your engine is at top dead center on the compression stroke now look down at your harmonic balancer the crank damper with the groved straight line back the engine crank counter clock wise till that line faces #0 on the timing marks plate above it leave it at 0 degrees now take your distributor cap off and see to make sure the the rotor is facing # 1 cyclinder if not take the negative by CutThePrice" style="font-size: 13px; color: rgb(22, 122, 198); left: auto; opacity: 1; top: auto; font-family: Roboto, arial, sans-serif; line-height: 17px; margin: 0px 0px 0px 3px !important; padding: 0px !important; border: 0px !important; box-sizing: border-box !important; bottom: auto !important; clear: none !important; display: inline-block !important; float: none !important; height: auto !important; max-height: none !important; max-width: none !important; min-height: 0px !important; min-width: 0px !important; overflow: visible !important; position: static !important; right: auto !important; text-transform: uppercase !important; -webkit-transform: none !important; transform: none !important; vertical-align: baseline !important; visibility: visible !important; width: auto !important; word-wrap: break-word !important; zoom: 1 !important; z-index: auto !important; font-weight: 700 !important; background-image: initial !important; background-attachment: initial !important; background-size: initial !important; background-origin: initial !important; background-clip: initial !important; background-position: 0px 0px !important; background-repeat: initial !important;">BATTERY CABLE off the battery and unplug the grey and white wire located on the firewall under the plastic cover it will be a single grey and black or white striped wire unplug that connector take distrubtor completely out of engine and reset it in so the thumb button rotor is facing # 1 cylinder ok now put your bolt back in and tight it just snugged for now until later on as you will have to rotated later now put your cap back on and look at the cap where you tighten the 2 screws down the screw in the front looking at that and at the top of the cap where the plug wires go count 4 plug inputs counter clock wise and start # 1 spark plug wire from there going clock wise fireing order now thats it now before hooking the negative battery cable back up make sure your number one spark plug is back in place with the wire on it ok now turn your head light switch on and off 5 - 7 times and now hook up negative battery cable back on it post and hook up the advance grey and black or white striped wire and now fire up your engine still no start turn the distributor clock wise till it starts and now your set have a nice day and dont forget to tighten the distributor down once you have it set to its right idle ok have a nice day !
Aug 25, 2014 | 1995-1997 Chevy 3500 Truck Ignition...
Yamaha 2005 150 HPDI wiring diagram
Looking for wiring diagrams for digital tachometer with trim indicators and warning signals. Mine had the plastic trip arm break. No trim reading on Tach face. Replaced trip arm forsensor arm and now have no reading on the tach at all except extremely light tach Number. All other electrical components work OK.
Jan 24, 2012 | Yamaha Motorcycles
I had two spark plug wires come off the coil,need the firing order on the motor and coil,It's a 3.9V6
STANDING FRONT OF VECHICLE CYLINDERS FACING YOU ARE 4 5 6 AND BACK CYLINDERS IS 1 2 3 NOW ON PIECE PAPER LOOKING AT IGNITION COIL PACK FACING YOU WRITE BACK NUMBERS 123 AND UNDER THAT NUMBER 1 2 3 WRITE FRONT NUMBERS 5 6 4 THATS YOUR COIL PACK PLUG WIRES LOCATION. LIKE I SAY 5 6 4 IS PLUGS WIRES LOCATION FACING YOU AND BACK NUMBERS 1 2 3 PLUG WIRES LOCATION ON COIL PACK. FIRING ORDER IS 1 4 2 5 3 6
Apr 04, 2011 | 2004 Ford Freestar
Where is the serial numbers located on the whirpool washer and dryer. its the basic ones
Normally the dryer model and serial numbers you are looking for is located on the drier door face of the machine where the door meets it. Look up top normally left hand side.
If it is not located there then maybe on the back of the drier.
Please rate me
Sep 13, 2010 | Dryers
Maytag drier de7600 connected new power cable to the 3 prong terminal on back of drier ground wire to the middle prong and the other wires to first and last. Drier does not start. What's wrong
check the breaker and make sure youturn it all the way off and all the way on. if you have a volt meter check the voltage from the two outside legs you should have 220volts
May 28, 2009 | Dryers
Which wires are hot and which is the ground wire on Maytag DE7600 drier (back panel top to bottom 3 connections)
If you have the newer style, you should have 4 wires on the CORD <--- not the terminal block itself. They'll be; Black, White, Red and Green. The green goes to the frame/cabinet and the white ALWAYS (ALWAYS) connects to the center terminal. The Black and the Red attach to either of the 2 remaining terminals... doesn't matter which one.
If you have a 3 wire cord, don't worry about a green wire. Just wire it "black, white, red" or "red, white, black"... just make sure you put the white in the middle. Think Oreo cookie.
And to be specific about your question... The Black and the Red are the "hot" wires... each one carries 120VAC.
SG
May 23, 2009 | LG DLE2512W Electric Dryer
Changing 3 wire to 4 wire cord on dryer [electric type]
If you had a 3 wire system and need to adapt your drier to a 4 wire system.. here is how you do it.. Your 4 wire cord should have the following colored wire ends.. Red, Black, White and Green.. The red and black are the power leads and should be attached to the red and black terminals on the back of the drier.. The White wire is Neutral and should be terminated on the white terminal of the drier.. The green wire is Ground and should be attached to the nearest frame or chassis screw at the point of entry into the drier.. If you are using a metal cable clamp as part of a feedthru system to get the cord into the drier.. you can attach the green wire to one of the screws on that.. but that should be done only if you canot find a suitable frame ground screw near the terminal block.. Hope this helps...
Aug 30, 2008 | Dryers
Dryer belt replacement
facing the drier get a small putty knife come about 1 inch from the edge of the drier and push in with the putty knife to release the plastic clip some times this can be difficult pull up on the top at the same time do that on either side till you get the top up then tilt the top back against the wall disconnect the door switch wires look in the drier to the front panel on either side you will see two 5/16 screws remove them tilt the front panel toward you and remove the panel put the belt around the drum slide it back to where you can see the old one has been running pull the idler wheel back hold tension on it and put the belt around the motor pulley let the idler pulley up till it engages the belt and reverse dissemble don't for get to plug the door switch back upimage3.gif
Jun 17, 2008 | Dryers
Maytag Neptune Dryer Raising the top
check your power first breakers trurn them off then on check outlet for 220 then 110 at each side that would be meter leads two flat holes 220 then meter flat hole on one side red wire black lead to round hole should be 110 red lead other side flat hole black lead round hole should be 110 if thats good then pull terminal block cover off check cord for loose or burnt condition if its burnt dont freak just replace terminal block and cord they burn if they werent tight when installed now to get the top up get a putty knife face the drier and about 2 to 3 inches there are two spring clips push in with the putty knife while rasing the edge one at a time if its not the power look for the thermal limiter a small metel disc close to the heating element some are plastic if its open theres your promblem pull one wire off of it or youll get a flase reading through the timer
Dec 26, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
