Question about Microsoft Xbox 360 Controller
My xbox 360 wired controller keeps on blinking on all four sides of the centre, and it doesnt work, how can i fix this problem?
    New Friend:
You stupid idiots.. do not see wired..
Posted on Dec 02, 2012
  • Justin Dec 02, 2012
5 Suggested Answers
SOURCE: Changes batteries and button blinks green light and wont' connect
clikc ont he button on ur xbox that looks like a bunch of arrows then turn on ur controller....this should solve it, if not e-mail me at silenthunder101@yahoo.com
Posted on Feb 15, 2009
m0bum
  • 94 Answers
SOURCE: Xbox 360 wireless controllers won't work
Try this:
hook them up using the play-and-charge usb cable
Then, disconnect the cable.
they should stay synchronized and worked fine after that.
Posted on Jun 19, 2009
19messiah65
  • 230 Answers
SOURCE: xbox wireless controller lights keeps blinking but
If the ring of light keeps blinking, it means that the remote controller was not connected to a receiver which is the XBox 360 console. Try to press the connect button on the console and the wireless controller to sync them together.
Posted on Apr 28, 2010
  • 22 Answers
SOURCE: Afterglow Wired Xbox 360 Controller Issue
Try to reset your controller with the help of a pin. look for the small hole and press the pin for a while it will reset the controller. i hope this will resolve the issue.
Posted on Jul 28, 2010
How I fix the xbox 360 controller blinking and sync light problem,when the sync button doesnt work?
My only guess would be that you disconnected the cable to the sensor while cleaning your Xbox. Have you checked all the connections before reassembling it? Check out the video I linked, maybe it'll help you!
Dec 16, 2014 | Microsoft Xbox 360 White Console
Yes, this can be tricky sometimes.
Be close to your console when synching your controllers. As always make sure the controller is on.
You will need to press both the synch button on the console and on the controller approximately the same time. If you have done this correctly. The controllers should have synched to the console in a few seconds.
Here is a link to show you how to do it for the Xbox 360.
Connect controller to your Xbox 360
To synch a Xbox One Controller go to link below here.
Connect wireless Xbox One controller to your console
Also just in case the light is flashing the and the controller is already synched, that means the battery is low and you need to change it out for new batteries.
Hope this has helped and good luck.
Just bought a used xbox 360 controller online. It is a wired controller. When i plug it in to the xbox I just get green blinking light
that means you have to many controllers registered to the system I have had this problem multiple times with my xbox if anything take a wireless controller or even a guitar hero or rock band guitar and take batteries out if that doesnt work then sync one of the controllers to a different xbox.
Aug 02, 2011 | Microsoft Xbox 360 Controller
None of my wireless XBox 360 controlers will connect to to my XBox 360. I have tried replacing batteries, syncing it with the system, turning my system off then on again, removing any obstructions near the...
If the wireless controllers won't connect under any circumstances even with the Charge-and-Play Cable then you most likely have a problem with a board inside your 360, i think it's like the RF board or something, mind you, the C-P cord only forces through an electrical charge and does not force the controller and console to connect, it just works when your batteries are low, in the event that your console is faulty, you can purchase RF boards and replace them yourself (voids the warranty but takes 20 minutes) or send it into XBox HQ (gives you more warranty but takes like 6 months)
Apr 16, 2011 | Microsoft Xbox 360 Controller
My wired Xbox 360 controller keeps blinking an it its plugged in properly. What is it?
Your 360 controller will blink when it's low on batteries. Plug it in or undo the clip on the back and replace the double A's.
Jan 21, 2011 | Microsoft Xbox 360 Controller
When I plug my xbox controller(wired) into the 360, it keeps blinking over and over. I think it might be a shortage because it only works if you move the controller around. Is there any way to fix this?
The only way to fix a broken controller is by purchasing the Tamper Proof Screwdriver from Microsoft. You could also try removing the plastic from the wire and see if there is a broken connection. If you find one, solder it back together and use heat shrink tubing to put it back together. I hope this helps!
Dec 22, 2010 | Microsoft Xbox 360 Controller
Xbox wireless controller lights keeps blinking but
Apr 27, 2010 | Microsoft Xbox 360 Controller
Controller NOT Working Properly
I just came home to find this same problem. Four blinking lights on the wireless controller and the inability to sync the controller with my 360. On a whim I took out my controller's battery and then reinserted it after a few seconds. Voila! Problem solved. Controller works normally again!
Jan 22, 2009 | Microsoft Xbox 360 Controller
Wired xbox 360 controllers lights keep flashing
if its wireless then it might be...well i dont know but if its wired then the cords could have streched out
(-(-(-NeRd-)-)-)
Dec 19, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Controller Logo
567 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
