Question about Samsung RS2630SH Side by Side Refrigerator
Yes my problem is that my refrigerator don't get cold any more for the pass 2 days, all it does is the light go on but nothing gets cold can you help me?
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
CSX22GRZAWW freezer works, refrigerator warm
Damper problem.
This ice box has a damper which is controlled by a thermostat. When the fresh side be warm that damper opens and allows cold air to enter the fresh food section. It must be gone out. it is what i would check.
Jun 12, 2012 | Hotpoint HSS25GFP Side by Side...
LG 26LX1D. Has worked for 2 years. Recently moved but the day I left I was still watching the TV and then wrapped it in a thinks blanket for protection and placed it ontop of several winter coats for more...
It's possiable the powerboard is just not filling those cap's to capacity, this would explain why the green light does not come on, also what can be possiable is a relay in the power board that is not passing the 110v. I am uncertain of cause.. However 5days would drain the capictors to a point where the refilling process failed. I am just wondering if it got could in the structure? IF so how cold. Eletronics only can handle a certain temp.
I would say power board.
Feb 11, 2012 | Televison & Video
Refrigerator section gets real warm, food spoils quickly but once I wiggle the control knob or just open the door and close it, it starts blowing cool air again. Why is it doing this?\r\nI was gone 7...
First of all thank you for all the information you posted, it helps greatly. Make sure your lights turn off when you close the door, very important. Next, I would suggest looking into a cold control, part number 2325701, if you have to tap on it, or rotate it to start running it maybe sticking and will cause the problems you have today. The link below is the part you need and you can order from this site or go to your local part house and get the part.
www.repairclinic.com/PartDetail/Temperature-Control/2325701/1408480
You can by-pass the cold control by using a jumper, be doing this you will turn the unit into a total freezer though. Be aware this will test you problem, but not cycle at temperature as design. Behind the cold control is a adaptive defrost board, this controls your defrost cycle and could also create the same problem. If the unit gets stuck in defrost, it does not advance like a timer, just when the thermostat opens inside the freezer.
To prevent confusion, I would by-pass the cold control, watch for freezing, if the unit runs with not problem for at least 6 hours, the cold control should solve your problem.
Good Luck
Aug 14, 2011 | Whirlpool W8RXEGMWQ (18 cu ft)...
Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Jan 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Aug 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Not cold anymore
You will need to unplug refrigerator and remove the rear panel in back of the freezer. Look to see if the evaporator coils are frozen over and if yes defrost with a hair dryer. Look at the bottom of the evaporator and you will see a defrost heater. Some have a glass tube on outside. Look to see if the heater is burned out. Then let me know what you find, Thanks, Sea breeze
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Dec 01, 2007 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
35 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
