Question about Dryers
My LG gas dryer has had the thermostat sensors replaced and reset twice already, but after a few loads it stops producing heat. I have taken off the new exhaust outlet as I think the flapper may be producing too much back pressure for the dryer. Now I'd like to try it again. How do I find the reset button that the repairman pushed on his last visit? Thanks, Scott.
  • 489 Answers
You will need to disassemble the top panel, the control board, the front panel and the drum assembly to get access to the reset switch. LG has posted that once the button has tripped, it is recommended that it be replaced rather than constantly resetting the button.
Good luck.
Posted on Oct 04, 2010
NO HEAT
air flow. you must make sure that your dryer vent hoses are free of lint. if you found a lot of lint in the bulkhead more than likely your vents are cloged
Dec 02, 2013 | LG DLG0452W Gas Dryer
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
LG gas dryer not coming on
I can tell you on the LG dryers there is indeed a "reset" for the heating/burner funnel (as you obviously know) on the right hand side of the funnel, however they also incorporate a no reset "hi-limit thermostat" on the left side of the funnel. Once it is tripped it must be replaced.This is only present on the gas dryers.
Oct 16, 2012 | LG DLEX8377WM Front-Load Electric Dryer...
I have a LG DLG5932 with no heat. I've taken the front cover off the unit as well as the blower cover. I've removed a lot of link from the blower unit. I also have pressed what appears to be a reset switch...
you may have a defective gas valve. there are 2 coils; one for 1st stage ignition; and, then the other 2nd stage coil takes over. ohm out your coils. there is also a flame detector that is attached to the flame tube body; could be bad? or, the thermostats themselves may need to be replaced.. always replace both the main and the safety reset t-stats together...
Mar 26, 2011 | LG DLG5932W Gas Dryer
Gas dryer runs but no heat
Hi
Thanks for using FixYa. Please check the things that could stop a gas dryer from heating:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor, timer, selector switch, sensor.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | LG WM-2277HW Front Load Washer
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
LG DRYER DLG2532W GAS
Dryer doesn't get hot. Replaced all the sensors and still it doesn't get hot. Doesn't get hot in any mode. All vents are clear. I'm thinking that maybe there may not gas getting ignited, but I know nothing about gas stuff and am not sure if thats the problem. Any ideas of what I should be looking at next?
May 15, 2008 | LG DLG2532 Gas Dryer
Not heating
The reset button needs to be replaced.  Once it has tripped, it loses it's setting and will trip at a much lower temperature.  This is a standard procedure that LG is telling all their techs to do.
Mar 24, 2008 | LG DLE2532W Electric Dryer
Not heating
Check the exhaust vent and make sure it is completely cleared out.
Oct 20, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
199 people viewed this question
Top Dryers Experts
