Question about Samsung LN-T4065F Television
My samsung tv model number LN46A500T1F power botton clicks and picture dose not show. Need help please
3 Suggested Answers
SOURCE: Samsung 52" plasma tv clicks constantly & dose
www.scribd.com/.../LG-TV-Plasma-Training-Manual - 7 hours ago
Above is a training manual link, this is what is used to train the engineers to service these sets, it gives invaluable information, and insight.
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Samsung, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have original parts on hand,
Hi, well I applaud you for maybe wanting to have a go, but you must make sure that you are starting in the right place, That is The Power Supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. That’s it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then that’s a prime cause of failure. Resistors, hardly ever go faulty, and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be able to say.. "Oh that’s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish, a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. The Tools you will need are A SERVICE MANUAL a Good Multimeter, a Signal generator, a Signal Tracer, pref an Oscilloscope, Soldering Iron, De-soldering iron, Probably, too, A SMT Hot Air desolderer (for the Surface Mount IC's), Compressed Air, An Anti-Static Wrist Strap, (MOST IMPORTANT, to prevent ESD), Cutters, Screwdrivers, sometimes, Torx, drivers too. Tweezers, are real handy, a magnifying glass, or eyepiece, a good strong white Light. OH, and you MUST have the original remote control too, (Sometimes one must obtain, purchase, a special “Servicing remote”) as one needs this to "Program" the Computer in the TV, after, and during servicing, and to be able to put the TV, into "Service Mode" too.
Posted on Jun 15, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a 42 inch
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Dec 23, 2010
Can you help me troubleshoot my TV? It has audio but no picture.
Use a voltmeter to confirm all the voltages are present when the TV is powered on. If they are all correct then replace the led driver.
Jan 13, 2018 | Samsung Televison & Video
Volume intermittently increases all the way to 100 and cannot be controlled by the remote
This happens with some models. You can open the TV from the back and disconnect the connector for the side control board. You will only have control via the remote but your volume issue should be resolved.
Apr 12, 2014 | Samsung Televison & Video
Samsung tv sound but no picture
Based on the class action suit against Samsung, it's likely the capacitors buldging. My TV purchased in late 2007 was a "victim" and the tv did the turn on/off with no pic or sound. There is a limited number of tv models and now a March 2013 time limit. To see if your TV is one that qualifies for a free inhome replacement, look at these links:
www.samsung.com/capacitorsettlement/
http://arstechnica.com/gadgets/2012/10/how-samsung-spent-300-fixing-my-out-of-warranty-tvs-click-of-death/ (shows pictures, model numbers, etc.)
The Samsung repair was quick, but I had to get the TV off the wall mount and ready for the repair. They don't take it down or do any of the cable/line connections. If you are unsure if your model is one that qualifies, call the special 800 number given in the class action ruling.
Mar 02, 2013 | Samsung PS50Q97HDX 50 in. Plasma TV
Samsung LN46A500T1F no power,
that" s main board problem . i meet one same stand so. replace back main board lcd tv working fine. try it. good luck!
Sep 06, 2012 | Samsung 460UX-2 LCD TV
Hi My Samsung TV model is LA32C450E1XZN. I restored my LCD TV and then I click analog auto restore channels option but my LCD failed to store channels.. please tell me how can I store my channels back to...
hi my samsung lcd is la32c450e1xzn but it dose not have farsi teletex what can i do? the samsung site dose not content of the upgrade of this model
May 23, 2011 | Televison & Video
I have 4 32" Sony triton TV's that turn on and off
I think problem in power supply section and it would be nice if you could provide exact model number of your Sony TVs, question headings show it is KV-32FS120 TV, please confirm to proceed further.
Thanks.
Sep 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Mar 20, 2009 | Televison & Video
Samsung 52' TV Is showing red
MY SAMSUNG TV MODEL NUMBER LE32R87BD IS DISPLAYING A RED FLASHING LIGHT ON THE POWER BUTTON AT THE FRONT OF THE TV THERE IS NO PICTURE PLUS IT WONT TURN ON CAN ANYONE ASSIST ME WITH THIS PROBLEM
Feb 06, 2009 | Samsung PCN5425R 54" Rear Projection...
Picture not showing up
dear bobbymrana,
i think the problem is with your picture tube.so plz contact your nearest service center.I dono your model and which part in mumbai.But one center commeon to all telivision is
COLOR TRAK SERVICES
Shop No.2 Yash Residency Sector 6
Airoli Mulund Road,Airoli Navi,
Mumbai
you can also click the link below to find the nearest service center
http://www.samsung.com/in/support/repairlocation/ServiceLocationsMain.do
select category as television..
If you really find this information is useful then plz rate this..
Sep 05, 2008 | Samsung TXK2554 25" TV
Televison & Video Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
