Question about Baumatic B609SS Stainless Steel Gas Single Oven
BAUMATIC BT2531SS WE NEED NEW BURNERS AND KNOBS, HOW DO WE GET THEM BOUGHT IN 4/4/05 INVOICE NO 59112LN
We have just bought a Baumatic osf60 oven, but unable to locate a manual online. Help please
where did you buy it .I would try the manufacturer through their website if they have one
Jul 26, 2015 | Baumatic Ovens
New element still not heating
you need to check the active and neutral connection at the element itself with a meter with the meter connected and correct voltage selection turn the temp up if you have voltage your new element is a dud if you have no voltage check temp controller BUT BE CAREFUL
Nov 21, 2013 | Baumatic Ovens
Hi I brought a Baumatic Microwave model GEM252TK and I need the spec to fit it in to my new kitchen and I cant find it cheers
You can download a brochure - with the dimensions of the microwave - free from here:
http://www.baumatic.com.au/smart/media/Baumatic_2010.pdf
The dimensions are at the bottom of page 25. You can view, print and or save this file. If you need the general specs e.g. power rating/features, you can find them here:
http://www.baumatic.com.au/smart/25l-microwave-oven-with-grill.html
Please rate this solution if you find it helpful. Thanks.
Oct 23, 2010 | Ovens
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
Aug 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
Baumatic B609SS Stainless Steel Gas Single Oven Logo
74 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
