Question about Aprilaire 600 Humidifier
How to change from summer to winter - Aprilaire 600 Humidifier
    Habit-Forming:
  • 156 Answers
Can you give a little more info? Usually depending on where you live, people use de-humidifiers in the summer and humidifiers in the winter. If you need a humidifier year around, there should be nothing you need to do uther than filter cleaning and checking the water valve and cleaning the pan of mineral deposits. Depending on your water, you might need to pour a cup of limeaway in your pan and let it run for a couple hours. Then drain it, flush it, and let it keep running.
Posted on Sep 28, 2010
Both hi and lo light flashing, unit will not go on (used twice)
I have 3 exact units of the SWM5750DN-WM also and after cleaning them and put away for the summer (used in Winter 2016), and taking them out now (Oct 2017) for use, and all 3 are blinking green lights! The manual doesn't even list the blinking lights as a troubleshooting info... This sounds like a common occurrence so you'd think Sunbeam should have that readily available!
Anybody have a solution? I can't believe they are this fragile??
Feb 20, 2013 | Sunbeam Warm Mist Humidifier, SWM5750DN-WM
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Jan 03, 2013 | Carrier SBP Humidifier
The light is blinking to change water panel. should i wait til the beginning of winter or do it now beginning of summer?
Hello, i would wait untill fall when thebheatingnseason will begin. Most likey you will be using your ac soon anyway.
May 18, 2011 | Aprilaire 600 Humidifier
It is running but the house is only at 20% after a full week. Why can I not get it to 35% of so? I see water running when the furnace is running, So, I know it is working. My house is only 1600 sqft and it...
a couple of things, is this new or old..
1. you should have hooked up to hot water side of water not cold
2. you should have summer/winter bypass installed
3. what is your outside humidly running.
Pleas rate this response with thumps up section thanks..
Dec 19, 2010 | Honeywell HE220A1019 Whole House...
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the compresser hardly runs. By turning the thremostate you can get it to run for a short period. I have 6 of these...
These Ge Zonelines have and ambiant Temp control on the unit when the temp drops it drops out the compressor and goes to electric heat. This keeps the unit from getting iced up. They do go bad and sometimes they shut off to soon. I just replace them and everything goes back to normal. They are located on the outside part of the unit. Just slide out the unit and it is located I beleive on the right side of unit Rus.
Dec 17, 2009 | Humidifiers
We have an old Aprilaire humidifier (Manual adjust)and having problems trying to figure out how to shut it off-for the summer.
close the by pass air flow valve. shut off the water supply and finally flow the thermostat wire to the transformer or the controller and shut off or disconnect. Unit should be serviced before winter. Cell may need to be replaced
Aug 10, 2009 | Aprilaire 550 Humidifier
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Nov 19, 2008 | Honeywell HE220A1019 Whole House...
Aprilaire 600 Humidifier Logo
140 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
