Question about Sceptre DCL 7A 17" Flat Panel LCD Monitor
Problems with monitor
I have had this monitor for just over a year. The problem that I have is that the display can look fine for a bit and then all of the sudden it changes, colors are off, what was once white is yellowish or green and then it randomally changes back to normal. I use the auto adjust key but it does not fix the problem.
  • leaann_427 May 24, 2008
    Other monitors work fine so I agree that it is probably the video interface. I am thinking that it may be cheaper to replace monitor than to have it repaired?
    Brigadier General:
  • 6,966 Answers
Hi leaann_427,
Offhand, it could either be the video interface (most likely) internal to the monitor or the PC's Video Card (least likely). To determine/verify, try using another monitor.
Should it be the video interface, chances are that it is heat related and/or leaky capacitors. The monitor has to be opened up and the internal circuitry checked. This of course would require that you be familiar with electronic circuitry and components, use of a DVM and possibly a soldering iron. Should you be uncomfortable with a DIY, then perhaps your best bet would be to seek the services of a qualified professional.
If it were the latter (video card), then it could be a matter of cleaning the pins at the bottom edge of the card with a pencil eraser. Additionally, a clean/new paint paintbrush may be used on the card itself to remove the accumulated dust. Should your PC be using a built-in video, then you would have to do the cleaning on the memory of the PC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on May 24, 2008
  • Louie  Role
    Louie Role May 24, 2008
    Hi again,
    Am afraid you are right. Not only in terms of $$ but likewise the time element. As it would seem that you would be asking a service shop to do the repairs, then that will cost you both time and money. Often the repairs would take some time to diagnose, order the parts/replacement PCB, do the actual repairs plus applicable service fee which would make repairing the monitor no longer economically reasonable. There are monitors being sold around 100USD+
  • 52 Answers
1. Please check the signal cable connections; make sure it's tight and secure.
2. Please check if there is any missing / bent pin in the signal cable.
3. Please connect the monitor to a different computer to eliminate a possibility of video card (in your computer) problem.
4. try going into the menu on the monitor to find a degauss option it should work
My acer lcd monitor of 18.5 inch is going through a problem in which a large number of black rays are appearing and flowing up and down in the screen.... so the lcd displays very badly so wat to do my...
It depends, if the lines are due to physical damage then the warranty is no good if the screen is faulty the your fine. the way to find out is if you apply a little bit of pressure to the line and it gets bigger then its physical, if not get your warranty out
Dec 06, 2010 | Acer Aspire DualCore2GB/160GB PC 18.5"LCD...
My monitor screen turned green..
Please check the VGA cable properly its working fine if any brokage then replace with goods one,if still same situation then your display setting has been changed from operating system .go to desktop /right click/properties/setting/advanced/select graphics card/graphics properties/color correction/and select all adnd apply it.
Nov 20, 2009 | ATI RADEON X1650 Graphic Card
Monitor wont support 1600x1200 resolution. it displays a four inch wide bar down the right side of the monitor. It worked fine for two years and all of a sudden this.
I had a similar problem recently, green bar down middle which became "scratchy" and would come and go. I fixed (I hope) by unplugging the plug to the internal LCD panel assembly, cleaning with IPA, and re-plugging. All the covers and metal shields had to come off to do this though, a bit of a pain, and risky to the front of the panel.
Or it could be a timing issue, I know the L2035 only likes to be fed the right graphics "timings" over DVI and VGA. If out, you'll end up with an offset picture that can't be fixed by adjusting position in the monitor's menu. Re-set to standard graphics driver timings and it goes away.
Oct 06, 2009 | HP L2035 20.10" LCD Monitor
HP L1906 flat monitor
why not test the monitor on another PC
works there good.,
if not the monitor is bad.
can be monitor bad, cables bad, power pack if fitted bad.
test it on another PC.
if bad monitor start a post how to fix a bad monitor (endless answers)
Mar 20, 2017 | HP vs19 (Silver) 19" LCD Monitor
Vista 64 bit will not display on an external monitor
To solve this problem you should see on your keyboard a FN key by the windows key this key activates the secondary mode of your keyboard it has to be held down for this mode to stay on as soon as you let go of the keyboard returns to normal you should also noticed that F1-F12 have different symbol's on the keys one of them should transfers the display to you external monitor to get it to go back jut repeat the above steps hope this helps
Aug 02, 2009 | HP Compaq Evo Notebook N1000c
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
AMW 19" LCD Monitor
go to NVDIA web site download the latest driver.
you need at least 32bit color to setup the monitor.
the 8-bit color is a default, that is why the monitor alway return to default size which is 800x600.
19" monitor should have minimum of 1280x1024 with 32 color.
don't up the color 256bit. the color will be off on the monitor.
Jan 25, 2009 | Dell Dimension 4600 PC Desktop
LCD Monitor stays on 4 bit resolutionm
Its your VGA card that's having issues with the LCD display. Try reinstalling the VGA drivers see if it works.
Jan 22, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Samsung 17" Flat Panel Monitor - Streaks
I had this same problem with my ViewSonic LCD monitor. I tried turning the monitor off from the button on the front, and tried changing the settings for the monitor. That didn't help. But then I unplugged it from the power source, and the streaks immediately vanished!
Dec 30, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Sceptre DCL 7A 17" Flat Panel LCD Monitor Logo
163 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
