Question about Goldstar KG6000R Window Air Conditioner
Ac unit not powering / starting up
I bought an goldstar ac unit and i followed the instructions on the box re the installation..... but the unit does not start ...I am getting no power to the unit. I did the test as instructed which is to push the reset button did plug in and the resset button pops up....but the unit simply isn't powering up.
I left the unit off for over 8 hrs before I plug it in ..the box had recommended 3 hrs for the gas to resettle.
Can anyone help.
  • Anonymous Jun 29, 2008
    Goldstar 6000 shows power cord on with green light but power wont come on unit. Has been working fine and moved to another house. We have 2 and both are doing the same thing.
  • lubbehusent Jul 27, 2008
    My Goldstar all of a sudden powered off overnight and I went to power on both with the remote control and the unit. It did not come on. I unplugged the unit and and hit the reset button. it did not reset. I hit the test button. no results. Im about to take the thing back to walmart.
  • 828 Answers
Did you try to plug a lamp into the same outlet as you have the A/C plugged into? It could be that you have no power at the outlet or the circuit breaker could be off or tripped. Something should run like the fan only position.
Posted on May 24, 2008
New goldstars have a reset button on plug. Hit button.
Posted on Jun 27, 2008
How can I get a copy of the installation instructions for the LG MV1502W over the range microwave oven? I can find the user manual, but not the installation instructions.
Try ManualsLib here: . This is the Goldstar MV1502W (or MV1502B). Since the LG MV1502B manual refers to the unit as the Goldstar MV1502, this is probably the same model.
I hope this helps.
Feb 17, 2017 | LG Microwave Ovens
The circuit on the plug keeps tripping when I turn the unit on. Goldstar wg6007
most AC`s have a start capacitor at the compressor pump, if this start capacitor is defective your compressor will not start and cause it to draw more current than is normal, when you turn the unit on listen, if you notice a humming sound like an ac hum than this might be your problem, other units use a relay to start the compressor motor and if this relay is defective your compressor is remaining in the start winding position and will also consume excess current, obtain a diagram of your unit and this will indicate the type of start device employed and go from there
May 18, 2012 | Goldstar WG6007R 6 000 BTU Window Air...
Where is the drain hole on goldstar window ac my ac keeps dripping water inside the house
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Forclosed house we bought & now AC wont turn on
Usually there is a disconnect box installed on the wall, near the A/C unit., there is a switch or a fuse block with fuses in it, start there.
Good Luck,
Apr 04, 2010 | Heating & Cooling
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
This goldstar air conditioner model is WG2405RY7 It has an energy saver, but the unit just keeps running and won't shut off, everything else works.
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Jun 29, 2009 | Goldstar M1003R Air Conditioner
Failure in comfort zone one
There is a capacitor connected to the motor on the compressor. If it fails, the motor won't start and the safety thermal cutoff will stop voltage at the motor terminals. There are fuses inside the power interrupt box on the side of the outside unit. One of them may have blown
May 09, 2017 | Amana Comfort Zone 18M33PCEH Air...
I've checked my sources and it looks like your best bet is to call LGE (Lucky Goldstar Electronics) customer service at 1-800-243-0000 with your model number and ask about an installation instruction manual or owner's manual. You may have to make them understand that you're wanting insatallation instructions and be sure to explian what you're trying to do. They do list e-mail as but I've found that e-mail gets ignored much more often than a phone call. I appreciate your rating of this answer. Good luck.
Nov 17, 2006 | Goldstar MV-1501 Microwave Oven
Goldstar KG6000R Window Air Conditioner Logo
518 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
