Question about Hotpoint Refrigerators
I have an old hotpoint fridge that was just given to me but the freezer doesnt seem to be cold enough,,,the settings are in the fridge side by side,,,normal is in the middle,,,what is the best setting for both,,,so the freezer is really cold,,,right now its on the n in normal. what happens if its too high? and if its too close to the wall will that affect the fan in the back so it wont freeze?
  • 828 Answers
First the air circulation over the condenser. Normally the air is drawn in on the front right side and discharge on the front left side at the toe plate. Make sure the cover is on in the back or the air will not circulate properly.
Second the temperature settings. Both sides are cooled by the cooling coil in the freezer compartment. Normal is a good starting point but you should use some type of temperature gage for the final adjustments. If you set the freezer temperature to cold it will run longer to bring down the refrigerator temperature to the balance and shut off point.
Next is the bad point. If it is a used second hand refrigerator and it has years of run time on it there is the possibility that the compressor is beyond its life span. Make sure the condenser is completely cleaned in the back of the unit behind a removable cover. this is the same cover I referred to in the first part.
Posted on May 24, 2008
How do I hook up water andice maker?
Hi i have a hotpoint fridge freezer both my lights are on at the top,1 red 1 green,my freezer does not seem to be cold enough,there is also little drops thats can be set to 1 or 2 what are they for? Think my food in freezer will need to be binned but my fridge is very cold.
Jul 27, 2013 | Frigidaire FRS26RLECS Side by Side...
My hotpoint side by side hss25gfpaww is not cooling on the fridge side but the freezer seems ok. Fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Hotpoint HSS25GFP Side by Side...
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Baumatic fridge freezer
It's still under guarantee. Take it back now.
Aug 25, 2008 | Baumatic 23 in. BDW5 Built-in Dishwasher
Hotpoint rfa70 fridge seems not to be staying cold
just give it time as the freezer has to come down to temp first
Jun 05, 2008 | Freezers
Freezer not getting cold enough
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
Refrigerators Logo
95 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
