Question about Toshiba 26AV502U 26 in. LCD HDTV
I own a Toshiba 26AV502U and the TV volume automatically lowers as if I was holding the respective button. Last night I had no issues but today this problem first surfaced. I checked to see if it was a button stuck on the remote or TV and found no issues. Don't know what else to try... help!!
  • eckoman13 Sep 28, 2010
    Is it better to repair/replace the module or get a new tv?
  • 130 Answers
Hi
first is your tv hooked on some converter cable hd device if so this unit could cause the problem if not you will have to replace the main module. This kind of problem is very rare on this type
Posted on Sep 28, 2010
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
AT NIGHT, TV SWITCHES ON AUTOMATICALLY AND CHANGES FROM SIDE AV TO OTHER OPTIONS, I.E. PC / HD 1 ETC. LAST NIGHT TV SWITCHES ON, CHANGED TO HD1 AND TURN VOLUME AUTOMATICALLY TO 0. CAN'T GET VOLUME UP. WHEN...
what you describe is almost impossible ..the only explaining is someone with a compatible remote control messing around with you ..so ...pay attention ..and after that if you are completely sure that this is out of case...Leave a comment and I will search for another possible cause ..
Mar 17, 2011 | Philips 42PFL5332D 42 in. LCD Television
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
Remote Control wont open manue on new tv
ensure the satellite receiver is turned on and the output from the satellite receiver is connected to the ant. in on the tv. on the remote control, press the tv button, then the menu button. from the menu, select settings, set input to ant. .
do this and let me know what happens so we can get this working
I will be available till 2:00am CST
clarkco
Feb 16, 2009 | Toshiba 26AV502U 26 in. LCD HDTV
We just purcased Toshiba 26AV502U, now the screen is blank
Heard back from Toshiba. They said to unplug the TV, wait at least 3 minutes, and then plug it back in. This should allow it to reset itself. Sounded too simple, but after doing just that the tv has worked fine for the last three days! Toshiba noted that if this didn't resolve the problem we should contact them to have a Toshiba Authorized service person come check out the tv. It worked for us, hopefully it'll work for you too. Good Luck
Jan 18, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Volume won't go up
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
Aug 07, 2008 | Samsung TXG2548 TV
Toshiba 26AV502U 26 in. LCD HDTV Logo
296 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
