Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Como ajustar el revelador en la fotocopiadora minolta 351 dialta
4 Suggested Answers
Kevin Hayes
  • 167 Answers
SOURCE: how do i get drivers for minolta dialtadi350
http://help.bt.konicaminolta.ca/
Posted on May 27, 2008
GodBlessU
  • 3513 Answers
SOURCE: No tengo treiber para konica
Thank you for contacting Fixya.com
Please download the drivers from the bellow mentioned link:
http://www.howtodrivers.com/model532191.html
Good Luck and God Bless.
Posted on Jul 21, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Cambie revelador a una minolta di 3510 hice todo el procedimiento de rutina y le di F8 y en la mitad del proceso dice que hay un error y saca el f33 salgo del modo de servicio y apago la fotocopiadora y la...
. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Sep 23, 2011 | Minolta DI2510 Black and White Copier
Como hago para grabar
Hello
Antes de usar su nueva grabadora de DVD, usted tendr? que ajustar el reloj y, si se ha conectado un
se?al de televisi?n, explorar el espectro de la se?al para desactivar debilidad de los canales
Para ajustar el reloj:
1. Encienda la grabadora.
2. Pulse SETUP para entrar en el men? de configuraci?n.
3. Utilice y para seleccionar el reloj sub-men?
y pulse ENTER
4. Utilice y para seleccionar la fecha y pulse
ENTRAR.
5. Introduzca la fecha actual con el teclado.
Alternativamente, puede seleccionar cada d?gito
individualmente pulsando y, a continuaci?n,
modifica con el bot?n y.
6. Pulse ENTER para fijar la fecha
7. Utilice y para seleccionar Hora y pulse ENTER.
8. Introduzca la hora actual usando el teclado.
Alternativamente, puede seleccionar cada d?gito individualmente presionando y, a continuaci?n, ajuste por
pulsando y.
9. Pulse ENTER para ajustar la hora
May 23, 2011 | Protron PD-DVR100 DVD Recorder
Quiero saber el significado del codigo 49 en la fotocopiadora dialta 470
Hola, este c?digo de error es un problema con la opci?n de fuente de papel, del paper vertical transport cooling fan motor o de la tarjeta de control ( control board). Reemplaze el motor si esto no resuelve el problema, cambia la tarjetade control.
Mar 03, 2011 | Computers & Internet
QUIERO SABER TODAS LAS ESPECIFICACIONES DE FUNCIONAMIENTO, CONSUMO Y MANTENIMIENTO DE LAS FOTOCOPIADORAS ESTUDIO 350
Esa informacion la podras encontrar en el manual de servicio de esta copiadora, esta informacion es muy extensa, tendrias que bajar este manual de alguna pagina de soporte como de toshiba.com el nombre simplificado como la puedes encontrar es sm450 a lo mejor asi lo encuentras en un buscador como google o yahoo, suerte.
Feb 24, 2011 | Toshiba e-Studio 350 Copier
Bandas de tiempo como va posicionado el timpo del siena
Hola.
Usted puede ajustar el tiempo a lo que es el momento correcto para su zona horaria. S?lo encienda el coche y la radio y encontrar el bot?n peque?o en la cara de radio para la hora y los minutos. Por lo general, la etiqueta H y Joe M.
Gracias por elegir Fixya!
Feb 16, 2011 | 2002 Toyota Sienna
Tengo imagen negativa kp/51hw40
Hola!
Pruebe los siguientes pasos para resolver el problema: Asegúrese de que las conexiones de los dispositivos son firmes y seguros. Trate de encender y apagar la opción de Digital Reality Creation en el televisor. Trate de ajustar la nitidez de imagen y ajustes del modo de la TV. Presione el botón FLASH FOCUS en el panel frontal del televisor. Esto modifica la convergencia. Si el problema persiste, pruebe a quitar el televisor de la pared a dejar y conectarlo a una toma de corriente directa sin ningún tipo de protector después de 1 minuto. Pruebe a pulsar el botón RESET en el tiempo remoto en el menú de vídeo y compruebe si funciona. Si el problema persiste, el servicio puede ser requerido.
Gracias por usar FixYa.
Dec 02, 2010 | Sony Televison & Video
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
114 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
