Question about Eureka 437AZ Bagless Upright Vacuum
Changing brush belt - Eureka 437AZ Bagless Upright Vacuum
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
You have to unscrew the base plate to access the belt.
Posted on Sep 28, 2010
Change a belt
You did not state your model or make so I can't explain how to change your model but most vacuums you must remove the bottom plate held on by screws that covers the brush roll, remove the brush roll and belt and reverse the process with the new belt. Some models have the brush roll held in by screws and/or brackets, some brush rolls slide down into slots. Replace the brush roll if the bristles are worn or frayed. If you are not replacing the brush roll remove the endcaps if possible and clear any hair or debris that has worked it's way in there.
Cogged belts are different from stretch belts and do not need to be replaced at least once per year like stretch belts do. You should still remove the brush roll at least once or twice per year to clean out debris. Maybe more often if it gets hair or strings wrapped around it which can build up causing friction and heat which can melt or damage the brush roll or even the nozzle housing.
Jan 29, 2017 | Vacuums
Brush not spinning and motor surging and not picking up
does the motor surge when you push it back & forth or when you raise & lower the brush end of vacuum?
if so it sounds like it needs a new belt installed.
the belt should be routinely changed every 12 months (some need to be changed sooner) do to the belt stretching.
changing the belt to see if that changes how vacuum operates is a cheep & easy fix.
Feb 07, 2015 | Vacuums
How to change vacuum belt on bissell 6583-x
I am not familiar with this model but the first step would be to
remove the brush bar cover...this may be attached by screws
or numbered tabs which are released in sequence starting
with #1. With the cover off pull the brush bar out and slip the
belt off the pulley. Be sure to buy the correct belt and line up
the groove on the brush bar with the motor pulley...put the belt on
the pulley and stretch the brush bar forward and insert into the
slots on the sides. I hope all this applies to your vacuum.
Regards,
Dennis
Aug 10, 2014 | Bissell Vacuums
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
How to change the belt on a Eureka powerline limited edition vacuum cleaner.
The belt is directly connected to the brush roller. Remove the brush roller cover. Pull out the brush roller. Remove all carpet strings. Change the belt.
Jun 11, 2011 | Vacuums
How do you change a belt on a dyson DC07
Turn vacuum over so you can see the brush.
Using a standard screwdriver, undo the three fasteners just behind the brush.
Remove the base plate.
Remove the belt.
Remove roller brush.
Place new belt on roller brush and center it in position.
Feed belt through the hole, and return brush to position.
Ensure the brush ends are located in the slots correctly.
Pull the belt over the motor shaft.
Rotate the brush a few times to ensure belt is centered and secure.
Replace the base plate, tighten fasteners, and rotate the brush a few more times to make sure it turns properly and the belt isn't caught.
Mar 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I change the belt? Do I have to twist the belt.
You do not have to "twist" the belt.
You should be able to find your answer at this URL:
http://www.bissell.com/product_search.aspx?searchType=main&searchtext=3522
Look at the users guide for information on changing the belt. I would suggest that while you are changing the belt, also take time to clean the beater brush, you have to remove it anyway to change the belt. Clean the brush as best you can and add some WD40 to both ends between the brush and the small plastic pieces that hold it in place with the vacuum.
Oct 08, 2010 | Bissell 3522 PowerForce Bagged Upright...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Installing a belt
1. Unplug the vacuum
2. Take the bottom cover over the brush off by removing the 3 screws
3. Switch the brush roll control lever to bare floor
4. Take the roller brush out
5. Put the belt around the small pulley from the motor
6. As you are putting the roller brush back in put the belt around the space on the roller brush - center the belt on that space - THE BELT WILL NOT BE TIGHT BUT THAT'S NORMAL
7. Reinstall the bottom cover with the 3 screws
THE BELT DOES NOT GO AROUND THE SILVER PULLEY CONNECTED TO THE BRUSH ROLL CONTROL LEVER
Dec 27, 2008 | Vacuums
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Eureka 437AZ Bagless Upright Vacuum Logo
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
