Question about Canon XL1S Mini DV Digital Camcorder
Every time I load my tape to transfer the footage it says "Remove the Cassette" and then the "Eject" word blinks. It will not rewinf, fast forward or play the tape. What can I do?
    Genius:
  • 1,812 Answers
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 28, 2010
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
I have an older (1996) Sony Handycam CCD-TRV211. I am using the player to transfer my old 8mm tapes to my computer. The player will play for about 4 seconds then stop. I get a blinking triangle with a...
How are you powering the camcorder ? Many will not transfer videos if battery powered, since the battery may fail. Try again with the camcorder mains powered, see if that helps. Have you cleaned the heads with a cotton bud and a little IPA ?
Mar 01, 2017 | Cameras
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
We own a Sony handy cam model CCD-TRV37 and the tape will not come out. When pressing the eject button a little yellow arrow blinks upward on the screen and a code C:32:20 blinks in the upper right corner....
Error C:32:20 indicates that the take up reel of the cassette that winds the tape into the video cassette is not taking up the tape fast enough thus causing slacking when unloading.
Remove the battery or power cable, connect, and perform operations from the beginning.
if this fails take the camera to a repairman to remove the tape manually.
Dec 01, 2009 | Video Cameras
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Will not display picture or eject tape.
most of no signal means dsr 11 or similar machines have dirty heads. When they get dirt sometimes, you can´t play a cassette and the machine turns off (with the cassette in).
I´ve tried several times to reload the cassette and I manage to make it work again.
with the cassette in and the machine off press at the same time power and fast forward.
When in fast forward press play and your head should be starting to be clean (takes 4 o 5 minutes
to get a clean picture). Normally the machine gives a code error like if it was a loading problem but
not nearly related
Mar 13, 2009 | Panasonic Televison & Video
Mini DV damaged
You have to make sure that when the tape was put back in the cassette, that it maintained it's side to head integrity, in other words, that it did not flip so at a certain point, the back of the tape is running against the drum and head in the machine. If that is the case, then you should insert the tape and rewind it and fast forward the tape 2 or three times and then let the tape rest for a day fully rewound or fully fast forwarded. This should iron out the small wrinkles, but unfortunately, the big creases in the tape will cause a loss of information so the picture will fail. You should transfer the tape immediately to your computer and burn a DVD as your tape has a very short life span now,
May 15, 2008 | Canon ZR100 Mini DV Digital Camcorder
Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Apr 04, 2006 | JVC HR-J461MS VHS VCR
Canon XL1S Mini DV Digital Camcorder Logo
74 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
