Question about White Sewing 1521
Neddle will not pick up bobbin thread - White Sewing 1521
  • White Sewing Master
  • 7,365 Answers
Check the needle to see if it's damaged
check the needle to see if it's in backwards
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Posted on Sep 28, 2010
Neddle bumps into throat plate
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever?,,,
May 23, 2015 | Sewing Machines
Were my bobbins goes it has a bobbin case but the case makes the machine stop and breaks the neddle what can i do
you are useing the wrong needles for the machine or the needle bar that holds the needle has slipped down from its retainer. and it will need the timing done. with the bobbin case out you will be able to see how much shorter the needle will need to be or how much the needle bar will need to move up. the hook that picks up the thread should line up above the eye in the needle on the up stroke
Jun 25, 2010 | Kenmore 15516 Mechanical Sewing Machine
Neddle not picking up bobbin thread
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 25, 2009 | Singer CE-100 Futura Computerized Sewing...
Neddle hitting the bobbon
does the hook assembly move when you turn the handwheel? If no, then your hook drive gears are shot.
Jun 07, 2009 | Brother LS-1217 Mechanical Sewing Machine
Tension settings for the babylock sewing machine
I found that the tension setting of 1 worked. The main problem was the machine had thread wound around behind the bobbin. I had to take the plates that are under the foot out, clean out the thread, oil the machine and use a spool of thread that had more weight than the little spool I was trying to use.
May 15, 2009 | Baby Lock BL1556
Needle doesn't connect with bobbin
hello there, do you mean you can't hooked up the lower bobbin thread to neddle bobbin thread, all you gonna do is to check the bobbin winding thread if it is in clockwise rotation when you pull out on the bobbins casing, insert the shattle casing, then manually rotate by your hand try to hooked up the bobbin thread by your neddle thread. let me know if you got it
regards.. rated me thanks
Mar 31, 2009 | Sewing Machines
White Sewing 1521 Logo
94 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
