Compressor get frozen at 74 f. - Heating & Cooling
    Sergeant:
  • 235 Answers
If you have freezing all the way back to your compressor, only a couple problems will cause this. Lack of airflow or a slower than normal fan speed. Check the filter. If it is clocked, your limiting your airflow across the coil. Then, if it's clean, look at the back of the coil where the air from the fan enters it. That is usually the problem. When you have a wet coil and a 35% rated filter, you are pushing dust into a wet coil and it usually sticks and looks like a lint screen. You might need to wash it out, but do so VERY carefully. Your fan motor is not rated to get wet. You might need to have an HVAC company come out and pull apart the plenum to be able to get to it to clean it. The only only other problem it could be is a slower than normal fan speed. If that's the case, I would recommend having an HVAC company come out to verify the problem.
Posted on Sep 28, 2010
  • 43,501 Answers
Your unit is probably low on charge or you have an air flow problem...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
I would like to set the cooling temperature on my LUX TX9600TS thermostat below 74 degrees. At this time I can not get it to go lower. Is there a way to change that ?
Lux tech support 856-234-8803. I Google your tstat info and there is a downloadable manual that explains it. If I read it correctly, set it to cool, hold menu button, when screen changes scroll to "cooling limit", enter 00(that's like a pass code), then it's probably set to limit at 74. Lower that setting. Now from a professionals opinion, someone may have set that to 74 because that machine may have a history of freezing up when set below 74. Most all cooling systems are designed for a 75°f indoor at 95°f outdoor temps and 55% RH(humidity). Anything beyond that is also beyond design specifications. So it may freeze up which has the potential of compressor damage.
Oct 11, 2017 | Heating & Cooling
Frozen compressor
A frozen compressor can be caused by several things. One cause could be partial loss of refrigerant or being over charged by someone adding to the factory charge. Another cause for a frozen compressor might be poor heat transfer in the evaporator, which is where the cool air comes from. This is usually systematic of a dirty evaporator or poor air flow coming from the fan. Another cause for a frozen compressor is the system not turning off when it should. This problem is usually a result of a bad thermostat or the thermostat not turning off soon enough.
JohnL
Apr 19, 2016 | Dometic Rooftop RV Air Conditioner
AC compressor clutch wont engage
Compressor will not run if freon charge low. If you want it to run supply direct power and ground to back of compressor. I do not recommend a home recharge as you will not be able to evacuate the moisture in the system and inject adequate amounts of oil
Apr 12, 2015 | 2007 Chrysler Town & Country LX New Cars
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Thermostat will not go below 74 previously would go to temp set.
Once it shuts down it will stay off for about five minutes to protect the compressor...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 08, 2010 | Sharp AF-S125MX Thru-Wall/Window Air...
I need the windage dial for my Bushnell 3-9x38 Sportview Rifle Scope 74-3938. The adjustment wheel is frozen.
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Mar 23, 2010 | Bushnell 3-9x38 Sportview Rifle Scope...
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
I have a york hvac system that is 5 years old. I have the thermostat set at 74 and when it turns on only the fan runs circulating the existing air in the house about 20 percent of the time. The a\c works...
It sounds to me like you have a delay on start timer on the compressor that possibly is starting to fail or someone may have adjusted the time band up on it. I myself would remove it and install a delay on break timer and a 5 minute setting would be ample time.
Hope this helps Ya
Jul 13, 2008 | Heating & Cooling
Kenmore refrigerator not cooling
You may need to clean the condenser under the refrigerator. Or you may need a new cold control. I did mean frozen as in iced up. If your coil is clear of ice as I understand then it is a different problem than a defrost problem. If your condenser has been cleaned and you still have the same problem you also want to check the compressor operation. Listen and if you hear a hum and a click at the compressor in the back it would be the compressor that has the problem.
May 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
