Question about Samsung RF265AB (258 cu ft) Bottom Freezer French Door Refrigerator
Display shows error "er" and "lc". Unit beeps for several seconds then seems to reset. What does the code mean?
MNTECH
  • 1543 Answers
SOURCE: door display shows ER WITH A UPSIDE DOWN HP
That stands for "error defrost heater"
Even though the refrigerator has gone through a defrost cycle, if a temp sensor does not reach a set temp within an hour, that error will display. You may have a bad defrost heater, defrost relay, thermal fuse, blocked defrost drain,..... something wrong with the defrost system anyway.
Posted on Aug 03, 2009
MNTECH
  • 1543 Answers
SOURCE: LG LFX25980ST REFRIGERATOR W/BOTTOM FREEZER SHOWS
The control is not seeing a feedback signal from the ice room fan. (the fan inside the freezer which pushes cold air up to the in door icemaker) It is probably blocked with a build up of ice or frost, preventing the fan blade from turning.
Posted on Oct 20, 2009
  • 53 Answers
SOURCE: er if reading on displayed, already replaced filter, won't reset
http://www0.epinions.com/review/pr-Kenmore_73503_Stainless_Steel_Refrigerator/content_164692332164
There is a lot to read, but you will know how your refrigerator works!!
Posted on Jul 04, 2010
dr appliance
  • 266 Answers
SOURCE: the display is showing ER FF WHAT
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Posted on Jan 27, 2011
  • 3 Answers
SOURCE: display shows LC and ER
I am getting the same code and for $75.00 the samsung rep is coming out to fix it. Let me know if you or anyone has info on this. I will post once I hear something also.
Posted on Aug 26, 2011
Samsung refrigerator beeping and code LC ER displayed, what does this code mean?
The code means Load Communication Error.
You will need a service technician. It may mean the fridge control panel board needs to replaced.
Nov 19, 2016 | Samsung Refrigerators
CD player displays error code: ER-1
That error code means an unknown error has occurred. Try cleaning the player itself, along with the CD's prior to insertion to see if that helps.
Feb 02, 2014 | Dual XD1228 CD Receiver
IE on screen what does that mean?
The codes these displays usually show that are hard to trouble shoot are:
88888 - This means the unit has suffered from dirty power or power surges and should be unplugged and plugged back in about 60 seconds later. This should reset the unit.
OF- Means the unit is in a Cooling OFF Mode, This is a power saving feature used by Retail locations. Some call it a DEMO mode.
PC-ER - unfortunately means your unit needs service.
IE - is a tough one, I would like to see it first hand but if everything is working correctly might possibly be a display error and it should be saying ICE - I have not come across this one in person.
Aug 06, 2013 | Samsung RF4287HA
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Our refrigerator constanly has ER FF in the ice & water display area. What does that code mean.
This error code ER FF indicates a problem with the evaporator fan motor but it can also be with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. But resetting the board does not solve the problem always. The Defrost Control Board being defective will also show this error. The best solution would be to look for your complete model number and contact me HERE and I will send you your models Service Manual and parts to look for, I will continue to publish manuals HERE, Thanks, Sea Breeze
Feb 20, 2011 | LG Refrigerators
I have an LG SXS side by side refrigerator that will not dispense water. The display shows FR & FF. If the supply is switched off and then back on again the display resets for a period of time. Over...
Er FF - Freezer Fan Error - This can be caused byfrost accumulationon or around the freezer fan. Unplug the unit for 3-4 hoursto allowthis to melt off. If error code persists, call Customer Service.
Jan 20, 2011 | LG LSC26905TT Side by Side Refrigerator
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Sep 28, 2007 | Maytag MER5775Q Electric Kitchen Range
Samsung RF265AB (258 cu ft) Bottom Freezer French Door Refrigerator Logo
865 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
