Question about Xerox Phaser 7760/YDX Laser Printer
My Xerox 7760 printer starts up when powered on, but it get frozen in the warm up mode. No fans appear to be operating, but the fuser is heating up.
Check the configuration chip and the imaging processor pwb for any fault.
Posted on May 13, 2013
At me the same problem
Posted on Oct 01, 2010
How to reset the fuser xerox 7760
NVM setting
  • 744-354 (Fuser Warning Point). Set it to 490.
  • 744-355 (Fuser Life Point). Set it to 500
Sep 15, 2014 | Xerox Phaser 7760/GX Laser Printer
Printer warming up don't stop
Try another wall outlet for power. Make sure it is not plugged into a ups/power bar etc.. but directly into the wall. A ups can limit the amount of power reaching the fuser and cause it to fail at warming up. Also try putting your hand near the fuser to see if it is giving off heat (don't touch it though, you can burn yourself)
Mar 28, 2014 | Xerox Phaser 3117
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
Xerox 7760 paper jam
at which position it will jam it matters tell in detail or send a sanp of it
Apr 10, 2013 | Xerox Phaser 7760/YDX Laser Printer
Model 7760 boots up to main menu but says it is warming up. Is this a problem with engine controller board ? Fuser is hot.
The Xerox Phaser must be connected to thenetwork via the ethernet cable or via the USB to a PC before you start it up.
If the printer can't "see" the network or PC via the Ethernet or USBconnections when you switch it on, the menu will display "warming up"continuously and when you try to access the menu, it will "freeze".When this happens, switch the printer off and make sure the Ethernet or USBconnections are connected properly before switching it back on.
Jun 29, 2010 | Xerox Phaser 7750DN Laser Printer
Hello i hope someone can help me with my problem i need reset the fuser uit xerox phaser 7760,because the rollers both(up,low) are like new condition thank you
You can get more life out of the fuser by removing one end and placing a piece of tin foil OVER the THREE FUSES, which are designed to blow at set times. Just tape it in place with some tape.
Good Luck
Oct 03, 2009 | Xerox Phaser 7760/YDX Laser Printer
I have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
May 20, 2009 | Xerox Phaser 7760/YDX Laser Printer
Printer lines
did you check the drum? it could be coming from the drum blade.
Jul 17, 2008 | Xerox Phaser 7760/YDX Laser Printer
Xerox Phaser 7760/YDX Laser Printer Logo
394 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
