Question about Kenmore Dryers
The dryer runs on all settings, but am getting no heat
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 28, 2010
1. When you set the timer knob for the dry cycle it gets stuck and dryer keeps running. 2 The dryer turns on and runs but does not always ignite to provide heat. Heat source LP Gas.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 20, 2011 | Whirlpool Dryers
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
The fuse for the heat keeps blowing but dryer runs
if its an old round buss fuse that screws in the panel(especially an old 60 amp panel),sometimes the center where the fuse lands the insulation gets weak in this area and lets it arc over when the dryer calls for current to heat the element replace this with a sub box and breaker set-up.the other thing it can be is the element is touching the units case and grounding out causing the same problem
Jan 25, 2010 | Kenmore 82822 Electric Dryer
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
It runs, but no heat
i dont believe at this time its anything mentioned at top most people dont realize that dryers are split cuircuts
is this a 220 setup
and if its a 220
the cuircuit breaker for this is set by 110 each one for the heating element one 110 for the guages and motor
goto circuit breaker and flip the breakers this should return your dryer working ability
other thing is are the guages working properly
dryer doesnt have to run to test guages turn to the highest setting and let them run completly threw cycle if they stop on a particular setting for a long length of period then the guages are bad
May 29, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
23 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
