Proscan PS35653 TV screen is to wide. I can's see the whole screen. Which is a problem when trying to read something off the tv
To wide to read ? i think u can adjust the horizontal or im buying proscans im trying to figure out what you mean does the print fade from side to side or ?
Posted on Jan 25, 2011
Need to replace the screen on a Proscan PLDED 3996A-E
You need to replace the whole thing as it will cost more than a new one to repair.
Apr 20, 2017 | Proscan Televison & Video
Proscan ps35653 will not turn on after recent move
yes it could be the problem of power supply.
Aug 31, 2008 | Proscan PS35660 TV
Getting 3, 2" wide gray/black lines in screen.
Please answer the questions in video to yourself and then give a more detailed description, as there are many reasons depending on what exactly is happening. TV Repair Help for Vertical Horizontal Lines on Your TV Screen...
Nov 28, 2015 | Proscan 32LB30QD 32 in. LCD TV
Can't get past blue screen with proscan what's wrong how the hell do you turn it on
do you have anything plugged in to it? the blue screen just means its not getting a signal. cable tv, roku. try switching between your inputs tell you see something on screen. hdmi. cable. you might also have to auto program for cable tv
Jul 26, 2015 | Proscan Televison & Video
I have a 42" Proscan
It sounds more like a backlight problem to me. The first thing I would try before tearing the set apart is simply unplugging it for about five minutes and plug it back in. TV's do weird things sometimes and need to be reset. Odds are, if you have to open up the TV, there's not a whole lot you can do anyway. Check the backlight on signal and also see if your inverter is working. I would suspect that if you're strobing your backlight is probably dying. In that case all you can do is replace the panel; you could try finding a replacement backlight and installing it, but I wouldn't advise even trying this. Replacing backlights is quite a task if you're not familiar with televisions. Anyway, best of luck.
May 01, 2011 | Proscan 42LED55SA 42 in. LCD TV
The screen to my 32" Proscan flat screen tv broke.
unless you have not mentioned your place its difficult. Better you find some importers,
otherwise contact the authorised service centre
Apr 09, 2011 | Proscan 32LB30QD 32 in. LCD TV
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
Jul 23, 2010 | Proscan 42LA45H 42 in. LCD TV
My proscan tv went into wide screen....everything shows up bigger. how do I get it back to normal? By wide screen, I mean if there are 2 people sitting at a table talking on screen at opposite sides of...
It sounds like you accidentally enabled a zoom feature or something similar.
Most remote controls should have a clearly labeled "zoom" button or a "picture size" option. If not, go into your TV's menu and look for something zoom related.
If this doesn't work, just go ahead and toy around in your TV's menu. I strongly suggest writing down the default settings so you can go back to them if you screw something up.
Aug 27, 2009 | Proscan Televison & Video
Proscan ps35653 chassis ctc169 picture to wide for screen
press the menu button on the front of the tv and then scroll down using the channel buttons to picture format, next change the format from widescreen to standard.
Jan 19, 2009 | Proscan PS36123 TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
