Question about Garmin Rino 530 GPS Receiver
Garmin 530 log on problems
Can not turn on my Garmin 530. If I plug in the battery charger it broadcasts weather but I can not turn the unit on and I can not adjust the volume or turn the Garmin off. The screen lights up and shows percent of charge but all buttons can only turn screen light on and off. Please help!
  • buscuit May 24, 2008
    I purchased the device last summer and used it last fall on a high country mule deer hunt. It worked great. over the winter I used it a couple of times to check weather and it has been on the shelf in my office since last fall. Leaving today for a fishing trip in central Pa and thought I would charge it befor going last night. As soon as I pluged in the charger norad weather came on . I did not attempt to turn the device on prior to connecting the charger and norad stops when I unplug the charger. battery is at 82%. It has never been wet. Other than that sign of life when charger is pluged in it is stone dead. Thanks, Meb
    Garmin 530 will not turn on. No sign of life in the device until I plug in the charger. At that time the screen lights up and norad weather starts broadcasting. I cannot adjust volume and all buttons only turn screen light on and off. Battery is at 82% and charges normally. Unit has been on a shelf in my office all winter and operated normally appx 90 days ago. Thanks for your help. Meb
    President:
  • 2,712 Answers
Could be a problem with the memory card. Please try to remove that then power up and see if the issue is resolved. If not, it could be a problem with the internal circuitry. If this is the case, then unfortunately, there is no other go except to get the device service.
Posted on May 24, 2008
  • 3,037 Answers
There is a glitch with this specific unit, you should try loading any software updates and then try to fully discharge the unit. If you can get it to discharge, then once you plug it in to the computer, try loading the updates which should prevent this from happening again. Let me know of any problems that you may run into while doing this and I would be glad to help all of the way until this is fixed.
good luck and please let me know if you have any further questions
  • Benjamin Patri
    Benjamin Patri May 24, 2008
    A little more into the glitch, when you think the device is actually off, it's not it is said to be on and the glitch prevents all buttons from working correctly, Once completely discharged, it should start working again when plugged back in.
  • Garmin Master
  • 13,433 Answers
I suppose you need to send it in for service.
    Sergeant:
    Champion:
  • 304 Answers
in the initial check of your problem, have you try to replace and change the battery of your device..?
`jack
  • 52 Answers
It sounds like it has a short circuit. try contacting customer service to see about them repairing it if it is still under warranty. also try updating the device. here is the update site http://www8.garmin.com/support/download_details.jsp?id=3515 here is the customer support site http://www8.garmin.com/support/warranty.html also if you just purchased the device within say 3 months the store where you purchased it from should replace it too
    Genius:
  • 1,142 Answers
Try a hard reset of the set.
Garmin Nuvi 260 Car GPS Receiver
When the charger is plugged into the unit, look at the main menu screen. If the charger is working correctly, the green battery icon in the upper right-hand corner eill go out. If the charger is plugged in and there is a light lit on the charger but you see the green battery icon in the upper right-hand corner of the screen on the main menu, then the unit is on battery power and the battery is not getting power from the charger. Common problem with these units are loose rear USB ports. More information can be found here:
http://www.sharc.net/gps_charger_repair.htm
Sep 06, 2013 | Garmin nuvi 260 Car GPS Receiver
Garmin nuvi 2555lm battery want charge
A common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
While you could have a bad battery, the Nuvi 25xx series is not that old and the date code on the battery is probably from 2010 or later.
If you plug in the charger, the green battery status indicator should go away or you should see a lightning bolt appear over the battery status indicator . If you don't see a change to the battery status indicator when you plug in the charger, then this confirms that the rear USB port is broken and not applying a charge to the battery.
http://www.sharc.net/gps_battery_repair.htm
Mar 25, 2013 | Garmin nuvi GPS
My rino won't charge
Two things occur to me: possible damage to socket where charger connects to unit------or no voltage from charge source to the battery
A lot of the connectors where the unit connects to power are easily damaged.
Nov 03, 2012 | Garmin Rino 530 GPS Receiver
Garmin 530 doesn't turn on
if the light goes off it would indicate that the battery is fully charged.
does the unit function like a phone when charging as in showing a chg indicator even if it is off? If so there are more serious issue than maybe just a bad power switch.
Oct 22, 2017 | Garmin Rino 530 GPS Receiver
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin 530 hcx won't turn on
I think I fried the lithium ion battery by having it plugged into the charger and the computer, hopefully covered under warranty....
Dec 14, 2008 | Garmin Rino 530 GPS Receiver
Garmin Rino 530 battery wont charge
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Nov 15, 2008 | Garmin Rino 530
Dead Garmin c550
had same exact problem. my unit would come on for a minute and then go black. if you take the silver ring around the face you will see the four screws to take the unit apart if you do have to replace the battery. however first try hitting the reset button on the right side of the unit. remember the cover needs to be off. i hit the reset and my unit powered on with no problems
Oct 31, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Garmin Rino 530 GPS Receiver Logo
166 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
