Manula for a Electrolux XL 8 kg jet system EWF 1090
2 Suggested Answers
  • 154 Answers
SOURCE: program lights not showing on front loader
You most likely have had the main control board blow on your Electrolux washing machine.
It is quite common for the main boards to blow on these machines. The main board is located on top of the machine towards the front right hand corner.
You need to remove the top panel via two screws on the back. Then slide and lift to remove top cover.
You will notice a white plastic casing fitted on the right hand side towards the front. This plastic cover holds the main PCB and is vertically fitted on a cross beam and has many wires going into it.
Get a quote for the part as they are expensive. Best to get a qualified repairer if you are going to replace this part, as there may be a problem elsewhere in your machine, causing the board to blow.
Electrical storms and power-surges also cause the boards to blow. Other time an electical short circuit or leaking water on electical components can cause this. Another item to watch out for are cocroaches. They can nest in the boards and short things out.
Ash
Posted on Sep 18, 2011
WHAT IS MEA'NT BY L60 ERROR CODE AT THE PANEL OF EWF 1090 ELECTROLUX WASHING MACHINE AND HOW CAN I SOLVE IT?
Hello - Are you certain the error code is L60? This manufacturer does not have any (L) error codes for any washer or other units.
Nov 30, 2012 | Washing Machines
Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Electrolux ewf 1090 , door lock fried, replaced PCB and door lock , not going
Hello - From what you have described it sounds like the washer could possibly have a communication problem with the control board not responding. Since you have already replaced the door lock, I would strongly suggest contacting a professional to accurately diagnose the unit.
Sep 28, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Program lights not showing on front loader electrolux jet system XL 8 kg
Ash
Sep 18, 2011 | Electrolux Washing Machines
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Apr 23, 2009 | Electrolux Washing Machines
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
