Question about Toto Carlyle 1-piece Elongated Bowl Toilet
My toilet runs constantly... how do i fix it?
  • 22 Answers
Chain it up so it cant get away!
Posted on Sep 28, 2010
The water from toilet cistern won't stop running into toilet
You have to check inside the cistern. Various valves may be contributing to leaking and constant running.
See this article:
https://www.familyhandyman.com/plumbing/toilet-repair/parts-of-a-toilet/view-all/
Dec 08, 2017 | Home
When hooked up to water my toilet will not stop running,does anyone know where the toilet shut valve maybe or is it an easy fix?
I have had this problem several times. The last time I dealt with this, though, our residential plumber showed me where the valve is. For us, it was right behind the toilet. That's where it should be for you as well. One thing that he taught us was to not have the valve turned all the way. That has really helped us to not have the water running constantly anymore. Plumbing Mechanical Residential
Jan 03, 2016 | Home
I have a american standard toilet mode 4112 that keeps running.....any suggestions on how to fix it?
The flapper ball may be contaminated and not sealing or the float level has changed and needs adjustment. You should be able to see if the overflow has water flowing into it continuously.
Mar 07, 2011 | American Standard 4112 Bone Toilet Tank...
Both of my Caroma toilets constantly "run",water is trickling constantly. How to stop those leaks? labels on toilets say: Caroma C Velle 305 EL SNV PAN made in PRC. Maintenance people from the...
Constant running can be due to a defective fill valve or faulty flapper. Try replacing either or both before discarding the entire toilet. One other possibility is that poor design results in poor operation.
Aug 07, 2017 | Caroma CARAVELLE270ADAW-EL Caravelle...
My toilet is a duravit 1930 series model with Euro style push flusher rather than handle. Internal flushing mechanism is not traditional float ball. toilet water constantly leaks from tank into bowl...
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
Nov 17, 2010 | Duravit Tribeca US-Type Elongated Toilet...
We have a crane toilet that worked perfectly and now it just wont quit running and water is leaking out the side how do i fix this im tired of shutting off the water to the toilet after it fills up
It sounds like it is running constantly because of the leak. Where is the leak, at the bottom, around the plastic nuts underneath or is there a crack in the tank? Let me know.
Fix the leak and will have fixed the running problem
Jul 09, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Our toilet has a much louder flush than before. Water is not constantly running. What is causing this and how can it be fixed?
Have you tried putting a pressure raducing valve before the toilet? the noise can sometimes be cursed by high pressure.
Mar 23, 2010 | Caroma 270W-RF Reflection Round Front...
Toto toilet is constantly running, even though the tank is full
it sounds like it might be the floater ball in the toilet you can adjust the tension on it usually with a screwdriver.... if you look from the top down you should see a screw on the top of the arm that holds the floater adjust the tension and hopefully this will work
Jan 20, 2010 | Toto Drake ADA Compliant Toilet with...
How old is the toilet? Might have lime buildup in the housing that's keeping the float from raising completely. The whole assembly is relatively inexpensive at Wal-Mart, and very easy to change. It would probably be less hassle than trying to fix the old one. I found that out after wasting a lot of time trying to mix my old one. :-)
Aug 30, 2009 | Kohler Toilet - One Piece with Ingenium...
Toto Carlyle 1-piece Elongated Bowl Toilet Logo
73 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
