Question about LG WM-1832C Front Load Washer
The washing machhine not washing - LG WM-1832C Front Load Washer
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^&*(
Posted on Oct 01, 2010
Our cash register will not turn on we just got done having a power outage and we need to know how to turn it back on
Its either the machhine is in sleeping mode or the power supply is blown. Unde the printer cover, you will find small batteries, take them off for some minutes then plug you machine it will liight up if it doesn't then you need to consult a technincian . good luck
Nov 01, 2013 | Royal Alpha 1000ML Cash Register
My washing machhine doesn't wash or rinse it only works on spin
If not filling with water check water is on and fill solonoid valves .
Jun 19, 2010 | Washing Machines
I have a brother ULT2001 Presently, it will not sew in reverse. Any suggestions? thanks
i have that problem sometimes and what helps me is if i turn off my machhine and then turn it back on. it works for me all of the time.
Feb 05, 2010 | Brother ULT2001
When entering the spin cycle, the motor turns the drum a quarter turn then stops for a second then repeats the process over and over but does not spin?
Hi.
If the machhine is belt driven check the belt first.
If the motor is variable speed the motor must be tested energizing it.
If you have single speed motor with clutch and motor couple system, check the motor coupler.
If this is a top load direct drive, check the transmission.
In all cases test the lid switch to ensure it is not opening contact when machine starts agitating.
If there is a motor control unit, that must be tested.
The wiring harness to motor, and also to MCU if there is MCU must be tested.
If there is no other fault , replace the timer board.
Regards.
Nov 13, 2009 | Washing Machines
Buzzing, Circuit breaking Century 110 Mig
Is the breaker large enough for the machhine? Chk machine amperage and up the breaker 30%.
Oct 28, 2009 | Welding Tools
Hi, I got a Fridgiaire front load washer. I got an error code E 41. Machhine won't start at all. Replaced the board. Now water enters machine for 15 seconds then stops will not spin
The E41 error means the control thinks the door is open. From your description of the problem the most likely problem here is a bad door switch assembly.
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Need to remove agitator
IF THIS IS AN OLDER UNIT THE AGITATOR WILL BE SEIZED TO THE SHAFT ODDS OF GETTING THE AGITATOR OFF ARE VERY SLIM. IT SOUNDS LIKE THE NUT UNDER THE CAP IS SEIZED ALSO YOU SHOULD BE ABLE TO REMOVE THE CAP AND THEN USE WRENCHES TO REMOVE THE NUT
Aug 09, 2009 | GE WDSR2080D Top Load Washer
Washing machhine takes water and then switches of
check for a weak circuit breaker...we need 15 amps alone...onthejob
Jan 30, 2009 | LG WD-14124RD Front Load Washer / Dryer
Boiling water in Miele automatic W750
Hi,after posting I had the enlightened idea to run the machine again.Gut told me it was a blip,rather than a defect.Has run 2 cycles with no problems recurring.We keep our fingers crosswise!regards henk
Jan 08, 2009 | Miele Novotronic W1918A Front Load Washer
Top thread keeps breaking
i have a singer sewing machhine that keeps breaking the top thread!!! it is not computerized!!! can you help me?
Apr 27, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
LG WM-1832C Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
