Question about Dualit Vario 3 Slices Toaster
The dial gets stuck and the toaster does not shut off. How can I repair this?
  • 61 Answers
You need a new timer they are available on ebay but they are pricey
Posted on Jan 05, 2011
Black & Decker Toaster Oven CTO650 ... Numbers around dials has worn off. Where can I get a replacement panel?
Search Results
    Black & Decker CTO650 1500 Watts Toaster Oven - Read ...
    www.epinion.com/.../Black_Decker_CTO650_Toaster_Oven.../3529132...
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints Is it really ... Cons:Numbers wear off around dials after years of wiping. ... It has a see-through glass door, 30 minute timer, variable temp up to 450 degrees F and signal bell.
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints i should'a bought this one Is it ... Cons: Numbers wear off around dials after years of wiping. .... It hasa 4-slice or 9 pizza capacity and touch button controls with LCD display.
Jan 28, 2016 | Toaster Ovens
I recently bought a Euro-Pro convection toaster oven and the timer switch has already broken. How do I get another one?
Call 800.798.7398. After polylingual promts, Select promts for "how to repair/replace your product", "Ninja or other kitchen appliances." Katie sd will send 3 knobsin the mail free of charge within 7-10 business days.
Jun 13, 2012 | Euro-Pro Toaster Ovens
The timer dial has stopped working. Is there an easy fix or does it mean a new timer from Dualit
This one of the most frequent problem of dualit toaster. Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch since it can not be repaired
Jul 28, 2011 | Dualit 40352 4Slice Toaster
The dial on the toaster keeps getting stuck.
This one of the most frequent problem of dualit toaster. Almost all have to be replaced after 5-8 years of use.Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch.
Jul 13, 2011 | Dualit 40352 4Slice Toaster
Hi, The dial on our Dualit toaster gets stuck on
The timer can be rplaced by any good handyman. You can get a new one on ebay there are two types make sure you get the right one. Replace it before someone forgets to shut it off and the toaster smokes up the kitchen. Its a common problem with the dualits but the switch is not cheap and you can only get it from England. The good news is the replacement seems to be better made than the original
Jan 09, 2011 | Dualit 20084 2Slice Toaster
The timer dial gets stuck repeatedly, resulting in very burnt toast that I have to rescue before a fire happens. I have not tried to fix it. This problem occurs now every time I use the toaster.
> occurs ... every time ...
How much would it cost to rebuild your home after a fire?
How many months would it take to rebuild?
How much would it cost to replace your toaster?
How many minutes would it take to purchase one?
Buy a new toaster, upgrading to 4-slices. :-)
Oct 05, 2010 | Dualit 20247 2-Slice Toaster
The timer on the front keeps getting stuck - this is a potential fire hazard due to the fact that the toaster sits under a cupboard on the work surface. Is it possible to repair? We live near Tunbridge...
Unfortunatly this a very popular problem with the timers and the only solution is to replace the timer knob complete.
Their are in ebay and amazon com, very good price and they wll arive to you in a couple of days.
Jun 24, 2010 | Dualit 40453 4Slice Toaster
The timer gets stuck and the toaster will stay on.
Open the bottom and shake out the crumbs. Kidding. Toasters are generally a disposable item. Depending on your affections for this crisping critter, you may find a part and you may not. I'm going to open a five dolar fis store for small appliances. So many are trashed because of penny parts. Let me have the make and model and Serial # and let me research this for you. Might as well open the doors here. This is a grand opening freebe.
Jul 01, 2009 | Dualit Vario 4 Slices Toaster
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
Door
On my toaster oven, sometimes the plate at the bottom of it would get stuck when shutting because the arms it uses to close it weren't very good.
I had to push it in with my hand to get it closed. (make sure it's cool)
Jan 08, 2008 | Oster 6260 1500 Watts Toaster Oven with...
Dualit Vario 3 Slices Toaster Logo
77 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
