Question about HP Computers & Internet
Iwant too kow how do you transilate a diskett on to a CD
    Problem Solver:
I am assuming by Diskett you mean a small flat disc 'bout 3"x3"Square)
1/. Use your burning program, when ADD Files comes up, select Drive A (Usually "A" is diskette drive) open,Add, Burn, ..Nero is pretty good.
I2/. F you mean one of those SMALL round CD type , just do it the usual way, (Same as above actually, just substitute your CD Drive letter for "A".
Hope I'm right in interpreting your prom, if not someone else will pick it (me) up on it and correct it..
Posted on May 24, 2008
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
Sep 24, 2012 | Computers & Internet
Tip
How to Flash a System Bios using a diskette or a CD
Not all PC models have the option of flashing the bios under the windows Graphical User Interface (GUI) environment. There are some that their manufacturers only give diskette option which will involve using the DOS (Disk Operating System) environment. Recently, the CD drive is also given as an alternative since most PCs now do not have diskette drives. Well in both cases, it will involve creating a bootable diskette or CD. Here's how to go about it:
First, you would have to visit the manufacturer's website and carefully check and download the latest driver files for your system model. Also, you would have to save the instructions for reference when necessary. If you are downloading for a diskette, you would have to download the driver files for diskette (they are smaller than that of the CD). Now, the next thing is to create a bootable diskette so you can copy the downloaded files to the diskette. The easiest way of creating an MS-DOS bootable diskette is by visiting www.bootdisk.com/bootdisk.htm, download an image (you can select 'Windows ME, Custom, No Ramdrive'), and follow the instructions to create your own bootable diskette. If the bios files you downloaded are zipped, you would have to unzip first so you can have access to the actual files and copy them to the bootable diskette. If you are downloading for CD, then you would have to select the one for CD if available. Normally, with the CD, an application is added to automatically burn the bootable CD. You would have to be sure your CD drive is a burner or writer. Take note of your drive letter (whether E:, F:, A: etc). Now you are ready to lunch.
If you are using a laptop, be sure to have your battery and adapter connected and if it is a desktop, then be sure to have a backup power like a UPS. Restart your PC and be sure to set your PC to boot from Floppy or CD depending on which one you are using. Now the PC will boot into a DOS environment. If the main application does not lunch automatically, you would have to lunch it yourself. In this case, you will see a drive letter and a blinking cursor. If the letter showing is not that of your drive, then you would have to enter your drive. This is an example of what to type if say we want to enter drive 'E';
c:\>e: (then hit the enter key)
e:\>
In this case, we were in drive C: and we moved from C: to E: by typing 'e:'. From the instructions, you will know the main file to lunch. This is an example of lunching a file with the name 'bios.exe' in drive 'A';
a:\>bios.exe (then hit the enter key)
In this case, we were using drive 'A'(normally the case with diskette). If it were to be drive 'E', it would have been;
e:\>bios.exe (then hit the enter key)
When this is done, you follow the instructions step by step to successfully complete the procedure. When done, you can check your bios settings if necessary.
Hope this was helpful and all the best.
on Feb 19, 2010 | Computers & Internet
Forgot password for parental control on Benq DV3080
Click here to download the user manual to your BenQ device. It will have all details.
It is not in English language. You can transilate it to English, using Google transilate option.
May 17, 2012 | BenQ DV3080 30 in. LCD Television
Instructions philips universal remote sru 3040
Download the user manual to your remote control from net. Click here to download it. If it is not in your language, transilate it to yours' using google transilate.
May 06, 2012 | General Electric Universal Remote Control
Rosetta stone cd not found
I had the same problem, and I figured that Rosetta was trying to access CD drive on drive "A", where Diskette drive is configured automatically by Windows 7.
I just disabled Diskette drive and Rosetta immediately found CD drive!
For further instructions on how to disable diskette drive read:
http://geekozoid.blogspot.mx/2009/08/how-to-removedisable-floppy-drive-on.html
My two cents
Apr 17, 2012 | Computers & Internet
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
4. Click Start
hope this helps you
Oct 19, 2011 | Computers & Internet
Can u teach me to read japanes code and signs
Hello
Get into Google. There is an option on the top bar "Transilate" Click it, and copy and paste the document you want to transilate in the drop down box. It will automatically detect the language of the document you have pasted to it. You will get option to transilate into your language. Try. It is an intersting feature with Google ofcourse. PK.
Jul 02, 2011 | Jensen Televison & Video
Nececito una foto del diagrama ya que unas piesas se quemaron y nose le ven las equivalencias
Hello
I've transilated your language from Spanish to English with Google transilate. Actually i want it to find out the exact equalivalent. OK.
May 13, 2011 | MTX Thunder 251D Car Audio Amplifier
Packard bell itreme 1908 will not restore from maufactures disk
Rob: Do you mean compact disc, or diskette?
If it is a diskette ("Floppy"), there is a chance that the information on the diskette is fried and useless.
If, however, it is a CD? When was the last time you cleaned your CD drive? It does need to be cleaned, best once a month. The "cleaner" is actually a CD with tiny brushes on it that clean the optics in the CD drive.
The CD itself could also be fried (badly scratched, dirty, or even heat damaged).
Dec 02, 2008 | Packard Bell (ATXGM28AP)
Computers & Internet Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
