What direction is the airflow so I know which way to put in the filter?
  • 43,501 Answers
Find a register that is blowing air out of it,,,,follow the duct work back to the air handler or furnace... that is the SUPPLY or the way that you want the arrows to point towards...
heatman101
Posted on Sep 27, 2010
Inlet manifold hoses changed on my ford focus since then car has been running very rough any ideas
did you change the filter and check the MAF, also did you put the MAF on the right way, has an arrow for direction of airflow. also with the MAF if it has been damaged or dropped, it needs to be replaced as they dont like to be dropped or banged about.
Jul 10, 2017 | Ford Cars & Trucks
What airflow does RHEEM RGLN 07eamer Furnance have? Is it downflow or upflow?
looks like Downflow
Rheem Classic Series Downflow Gas Furnace cdn.globalimageserver.com/fetchdocument-rh.aspx?name=rgln... · PDF file Rheem Classic® Series Downflow Gas Furnace FORM NO. G11-519 REV. 1 RGLN- Series ... RGLN- SERIES 05EAUER 05NAUER 07EAMER 07NAMER Standard Filter ...
Feb 18, 2016 | Filter Heating & Cooling
Where are the cabin filters located on a 2004 aztec?
The cabin air filters (2 of them) are located through the glove box. Open the glove box door and remove its contents. You will see a door in the back. Deflect the lever and gently pull out at the same time. This will expose the filters. There are two of them so take note there position as you remove them. You should also observe any indicators on the filters that identify airflow direction. Put the new filters in with the airflow indicator pointing in the right direction. Replace the door and the glove box contents and close the glove box door. You should be good to go!
May 22, 2012 | 2004 Pontiac Aztek
Cutting out like no power some times put a fuel filter on did not help
You may want to check the air flow meter, if it is dirty that can cause that issue.
the air flow meter can get contanimated by inlet air environment and Wet air filter oil, the airflow meter is the sensor in the intake hose and is very fragile, it can be cleaned by airflow sensor cleaner or break clean and letting air dry. Try that, or take to local honda dealer, you never know if there is an update to the ECU and they know the vehicles very well.
Mar 10, 2011 | 1997 Honda CR-V
I have some heat, burners on, is there a way to get more heat air filters clean i dont know what to do
If you are using a pleated or high efficiency type filter, that is a problem, the high efficiency filters
actually restrict a great deal of airflow, a AC unit requires 500 cubic ft per minute of airflow per ton of refrigeration capacity, 500 sq ft of home per ton generally = 1500 sq ft home has a 3 ton unit or needs 1,500 cfm of airflow, both in heat and cool modes, Honeywelll Enalysises prove these filters even when new reduce up to 500 cfm of airflow, effectively making a 3 ton system a 2 ton in output due to airflow restriction, try removing that filter with the fan on, it likely is pulled in sold with a huge pressure drop caused by tj filters obstuctive flow capabilities.
And 755 of all A evaoprator coils have been plugged or restricted by dust , dirt, oils from cooking, cigarrettes, running with no filter etc, a chemical cleaning of the evap coil above the firnace, or brlow it is indicated as a possible issue. Use the cheap 99 cent seee through filters we used to use
Dec 27, 2010 | Honeywell Programmable Thermostat Heater
How do you change the engine air filter in a 2008 toyota sienna
REMOVE ENGINE COVER DISCONNECT MASS AIR FLOW SENSOR CONNECTOR.LOOSEN AIRDUCT FLOW TUBE SCREWS THEN REMOVE AIR FILTER COVER HOUSING BOLTS THEN RAISE AIR FILTER COVER UP SLIGHTLY ENOUGH SLIDE IT AWAY FROM AIRFLOW DUCT.THEN REMOVE COVER REPLACE AIR FILTER THEN PUT EVERYTHING BACK UP VISA VERSA DONT FORGET TO TIGHTEN SCREWS TO AIRFLOW DUCT TUBE ONCE AIR FILTER HOUSING BACK IN PLACE.
Aug 31, 2010 | 2008 Toyota Sienna
Where is the cabin filter located
Hi, not all of the Caravan models have cabin air filters, a category into which the 2000 3.3 v6 seems to fall according to Popular Mechanics. A list of what years do have filters may be found here: http://www.autopartswarehouse.com/mmp/dodge~grand_caravan~acc_cabin_filter~parts.html
The filter is located in a vertical position under the passenger dash near the center console. Access it by locate the tabs to remove the cover and then pull the filter down and out. Make sure to note the direction it folds at halfway (toward the door) and the airflow arrows (toward the center console). It's a tight fit with the floorboard, but the filter is flexible. Put the new filter in facing the same direction as the old one. Directions (with pictures) are generally provided inside the box of the new filter; they may also be downloaded as a pdf from this site: http://www.micronair.us/assets/pdfs/21.pdf
Take care
Jul 30, 2010 | 2000 Dodge Caravan
1994 FORD TAURUS LX FUIL PUMP
does the car start and idle?
If so, replace the fuel filter - being you put in a new pump, then filled the tank, driving to the station may have caused seditments to get into the filter and plug it up.
Also, find your MAS (mass airflow sensor) and with car running, tap on it with a screwdriver handle (or small tool) -- if the car dies, or stalls, (idle fluctuates; more so than while just idling); you can first purchase MAS spray cleaner - remove, spray inside (honeycome) generously, let air dry for 15 or 20 minutes; install and start engine - tap again with small tool, and if it still dies, stalls, or fluctuates, replace the sensor (MAS).
Also, make sure that if you already installed a new fuel filter, that it is facing in the right direction. On most (inline {near tank} filters}, there is an arrow that should point toward the front of the car (or if mounted horizontally (from one side of car to other, facing both directions) make sure the arrow is facing the driver side.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jul 19, 2010 | 1993 Ford Taurus
My '83 320i is in neutral revs up fine, however when I put it in gear it feels like something is holding it back. it's not the clutch. The RPM's crawl up the tach. the engine gets louder but sounds muffled...
the airflow sensor is the box like item on the airbox tubing b4 the airbox its self there should be a solid plastic tobe/pipe between 2 rubber 1s with a wiring plug attached this is the airflow meter/sensor
Oct 02, 2009 | 1988 BMW M3
Infocus Lp290 Will not stay on.
Check the area around the fan and make sure you have good airflow. Put a small fan near the unit and direct the air flow so it cools it and let us know.
Aug 26, 2007 | InFocus LP290 1100 Lumen XGA LCD Projector...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
