Question about Symphonic ST419E TV
Need original remote for tv
I bought a used symphonic tv model ST131B and I can only get the lower channels without having to pay for a cable box. It needs to be programmed for the higher channels but a universal remote will not program it. I need the original remote that was made for that model. Any idea where I can get one or another way to get the higher channels without putting a cable box on it. I have cable but its split into the room so I don't need a box.
  • Anonymous Mar 24, 2014
    how can I change the channel without tv remote and no box
    19 in symphonic model number b-19wm can i change and wacth cable tv channels without a remote or cable box
    Scholar:
  • 143 Answers
Okay, after searching for a bit, I found a site that sells one for $19.95.
Click here.
It says that this replacement is exact function of original.
Posted on May 24, 2008
How do i get to the input of the symphonic tv model:sc3813
You should be able to access the A/V input by cycling through all available channels (using the Channel Up/Down buttons). You may need the A/V device to be powered on. However, if you programmed the Channel list to skip Aux, you may need to add that back into the list. You need the Menu function on the remote. Use the Up/Down arrows to navigate to Channel Set Up. Then press the F.Fwd (right arrow) to enter the sub-menu. Then select the Add/Delete Channel option.
Another way to access the A/V input is accessed by pressing the Game button on the original remote. (This also adjusts the screen lighting.) The game button is the middle button on the last row of buttons on the remote. If you do not have the original remote, you need one that matches that function. Here is one that is guaranteed to work: http://remotes.com/store/symphonic/sc3813.html . This one may also work: http://www.emtcompany.com/symphonic-sc3813-remote/rc64.html .
The Symphonic SC3813 was manufactured by Funai. The manual is available from Funai service support: http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/ . The direct link to the manual is http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/SC3813.pdf .
I hope this helps.
Mar 01, 2015 | Symphonic SC3813 13 in. TV/VCR Combo
I have removed all cable boxes from my home. I cannot get the tv remote to change channels. I was told by the cable tech that I needed to do a channel search. How do I do that?
Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here: http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
Jan 25, 2012 | Polaroid Televison & Video
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Have a symphonic tv model number wf24t5 and lost the remote... is there any way without the remote to turn it onto game mode
Yes go to menu with the buttons on your TV and go to CATV sometime u can press your channel button until your channels run out and if u keep pressing the channel button it will go into game mode or in other words switch to the RCA jacks in front of your TV
Aug 13, 2010 | Symphonic ST419E TV
Is this tv able to use the convertor box to get digital signals?
Here is the manual: http://www.symphonic.us/pdf/om/SC313D.pdf Follow the instructions for connecting a cable box to connect your converter box. Front panel buttons can be used to make menu selections if you do not have a remote.
Jul 12, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Mar 12, 2008 | Televison & Video
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
May 23, 2007 | Symphonic ST419E TV
Symphonic ST419E TV Logo
76 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
