Question about Apple iTunes
We have a new computer and are running window 7, when i click on the itunes icon it will not open? ta
    President:
  • 2,291 Answers
Click Start, type regedit, then press Enter. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers Its better you clean/repair Windows registry with RegInOut. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry. 5. Start iTunes. The offending message should be gone!
Posted on Sep 29, 2010
Ipod classic won't sync with itunes 10
Restarting your computer is often the solution when your iPod fails to sync with your iTunes music library. But if this fails, there are other troubleshooting steps to take.
Recharge your iPod via a USB cable connected to your computer or AC adapter. b> Click the help menu in iTunes and check for updates. Follow the onscreen prompts to download and install the latest version of the software. Open the new version of iTunes. Click the name of your iPod in the source list and check for updates under the summary tab to update your iPod. Attempt to sync your iPod with iTunes. Slide your iPod's hold switch to the hold position and then to off. Press and hold the menu and center buttons simultaneously until the Apple logo appears to reset your iPod. Open iTunes on your computer and reconnect your iPod to try to sync it with iTunes. Restart iPod service b> Close iTunes and make sure your iPod is disconnected from the computer. Click the 'start' button. Click 'run' if using Windows XP. Type 'services.msc' in the run box in XP and in the search box in the start menu in Windows 7 and Vista. Press 'enter.' Scroll through the list and double-click on 'iPod service.' Click the 'stop' button and leave the properties window open. Connect your iPod to the computer. Open 'my computer' or 'computer' and look for your iPod listed in the devices with removable storage section. Click the 'start' button in the iPod Service's properties window. Open iTunes to attempt to sync your iPod. Close the iPod Service's properties window once your iPod has finished syncing. Resolve "Original File could not be Found" Double-click the name of a song in the iTunes program that failed to sync to your iPod. Click 'yes' or 'locate' to the message asking you if you want to locate the file. Navigate to the folder or directory location where the song is stored on your computer. Double-click the song file to select it and add it back to iTunes. Reconnect your iPod to the computer and open iTunes to restart the syncing process. Some songs in iTunes won't copy to iPod http://support.apple.com/kb/TS1420 iPod classic Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/classic/
Apr 12, 2013 | Apple iPod MA446LL/A MP3 Player
Tip
How can I "disk use" on using the iPod Touch
<p>Apple iPod Touch can be used as more than a portable music and media player. Apple iPod Touch into a file storage device as the "disk use" setting in iTunes. Once the disk use is enabled, you can use your iPod Touch with any USB portable storage device and store your personal documents, files and backups on the device. <br /> <p><br /> <p>1. Connect your iPod to your computer using the USB cable. <br /> <p><br /> <p>2. Running iTunes and iTunes automatically start when your iPod. <br /> <p><br /> <p>3. Select your iPod from the "Devices" list on the left of the iTunes window. <br /> <p><br /> <p>4. Click the "Settings" tab in the main iTunes window. Go to the bottom of the screen and check "Enable Disk Use" option. The iPod Touch is now available for use as a portable storage device. <br /> <p><br /> <p>5. Open your iPod Touch from the computer's file browser. In Windows, select "Computer" from the Start menu and double-click your iPod. In Mac OS X, double-click the iPod icon on your desktop. <br /> <p><br /> <p>6. Copy your personal files to your iPod. <br /> <p><br /> <p>7. Eject your iPod to your computer. In Windows, select "Safely Remove Hardware" system, Mac OS X, drag the iPod icon on the desktop to the Trash. <br /> <p><br /> <p>8. Disconnect the iPod from your computer when you disconnect the USB cable. <br />
on Aug 08, 2011 | Apple iPod touch
I downloaded iTunes 64-bit to my new viao laptop, which runs windows 7 64-bit. This is the second time I have installed iTunes as I recently had to to recover my hard drive due to other issues (my laptop...
Go to start and left click,now left click all Programs.
Look for the Itunes folder,you need to right click the folder.
A new window will open,(Itunes Properties) Under the Properties you will have five tabs along the top of the page.
Left click Security,now in the center of this window you will see(To change permissions,click Edit.)
You must left click the button on the right side (Edit).
A new window will open called (Permissions for Itunes)
In this window you can set whatever option you want,doing this will set the default to whatever you select.
If want full control,just left click in the upper window on the "Administrators(the name of your system\Administrators) after you have left clicked that go to OK and left click then left click on the OK in the first window.
Thats it your done,now every time Itunes is started,it will run as Administrator.
You wanted to know why you were getting two Itunes icon's on the task bar,well one was running as Admin and the other was running as the default "Everyone".The Everyones default has two unchecked settings compared to the admin.You will not have two running anymore.
Hope this has helped you don't for get to rate....
Feb 18, 2011 | Apple iTunes
Pleas help my, I install I tunes 10 on windows 7, after that all icons on desktop get itunes loco, and itunes opens if you click it
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
Dec 21, 2010 | Apple iTunes
Hi I am unable to use itunes on my computer. I installed and its asking to turn off the compatibity mode. And also I cannot view summary, photo etc tab on my iphone device.
Hi
First of all
1. Exit out of iTunes.
2. On the Windows Start Menu select Computer or My Computer Depending on the OS
3. Browse to the following location: C:\Program Files\iTunes.
Note: Windows 7 (64 bit)browse to C:\Program Files (x86)\iTunes.
4.Right-click on the iTunes application (iTunes or iTunes.exe) and select Properties.
5. Next select the Compatibility tab.
6.
Ensure that the options Run this program in compatibility mode and Run this program as an administrator are not checked. If they are checked please deselect these options, then select Apply, and OK. You should now be able to open iTunes with out receiving the error message about iTunes running in compatibility mode.
This should fix your problem.Still if your facing the same problem after performing the following steps:-
7. Open the Registry Editor by selecting the Windows Start button, typing regedit into the search box or the run box depending which OS your using eg- xp,vista,7 and then pressing Enter.
8.
Browse to the following location in the registry editor, HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers, and highlight the Layers folder.
9. Delete the entry for the iTunes application (iTunes or iTunes.exe).
10. Close registry editor and restart the computer
You should now be able to open iTunes without receiving the error message about iTunes running in compatibility mode.If not please reply
Thanks & Regards
LOnG LIvE tHe GeeKs!!!!!
Dec 09, 2010 | Computers & Internet
I downloaded itunes on my new laptop. Once downloaded all of my icons I open, open Itunes? they also have the itunes symbol next to each one??
When installing, many programs associate file extensions in Windows with the program. In your case, iTunes associated all file extensions it supports with itself, hence the icons.
Depending on the Windows version, you can change this in the Explorer, or using the default program options (Vista & Windows 7).
Aug 12, 2010 | Apple iTunes
How can i turn off the compatibility mode of my itunes
First u need close the itunes.
1: Windows XP and Windows 2000: On the Start menu, click My Computer (or double-click My Computer on the Desktop).
2: Windows Vista and Windows 7: On the Start menu, click Computer.
3. In My Computer, open the C:\ drive (or whichever disk your Windows is installed on). Open the Program Files folder or "Program Files (x86)" if you are using a 64-bit version of Windows Vista or Windows 7).
4. Open the iTunes folder.
5. Right-click on the iTunes application (iTunes or iTunes.exe) and from the shortcut menu, click Properties.
6. Click the Compatibility tab.
7. Deselect the checkbox under Compatibility mode if it's selected.
8. Click OK.
9. Open iTunes and play a song.
This should take care of the problem.
Jun 23, 2010 | HP Pavilion dv6000z Notebook
Itunes .exe has been set to run in compatibility mode for an older version of windows. i already tried to change version but cant find windows 7 version also turned off compatibility still no luck
Unfortunately, even though I'd turned off compatibility mode for iTunes (by right-clicking the iTunes icon, choosing Properties, clicking the Compatibility tab, and clearing the Compatibility mode checkbox), the program generated this irksome message every time I ran it:
Sigh. Stupid Windows. Or maybe stupid iTunes. Either way, compatibility mode was "off," but iTunes didn't think so.
Fortunately, I finally found a solution:
3. Navigate to this Registry location: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
Dec 16, 2009 | Apple iPod MA446LL/A MP3 Player
How can i put music on my iphone using itunes
1. Open iTunes. Open the Edit menu on Windows or the iTunes menu on a Mac. Click the "Preferences" option. Make sure the "Disable automatic syncing for all iPhones" check box is selected.
2. Plug your iPhone into the computer and wait for iTunes to recognize it. Click on your iPhone's icon on the right side of the iTunes window. Click the "Music" tab.
3. Select the music you want to sync to your iPhone using playlists. You can also select the option to sync all your music to the iPhone.
4.Click "Sync" when you're done customizing your settings.
Get more details: Transfer music files from Mac to iPhone
Nov 05, 2009 | Apple iPhone Smartphone
Itunes
Hey 0836,
If the error message you are seeing reads as "QuickTime failed to initialize. Error # - 2096" you may wish to turn off Compatibility Mode for QuickTime, as doing so may resolve this problem.
You should be able to disable Compatibility Mode by doing the following:
1) Right-click on the QuickTime Player program and choose the "Properties" option from the menu that appears. Normally the application is kept in the C:\Program Files\QuickTime directory, but may differ if you chose to have the program installed onto another hard drive or in another directory.
2) Once in the "Properties" menu, click on the "Compatibility" tab.
3) Uncheck the box that says "Run this program in compatibility mode" if it is currently selected.
4) Click on the "Apply" button.
If QuickTime was not initially in Compatibility Mode, and you still receive an error message prompting you that iTunes requires Windows 2000 or later (or prompts you to make sure that compatibility mode is disabled in iTunes.exe), you may wish to try the following instead:
1) Shut down iTunes.
2) Click on the "Start" menu, then on "My Computer." You can generally also double-click on the "My Computer" icon on your desktop as an alternative.
3) Once in "My Computer," open the drive where Windows XP is installed. Typically this is the C:\ drive, but please remember that your configuration may slightly differ if you have multiple hard drives.
4) Open the "Program Files" folder.
5) Open the "iTunes" program folder.
6) Next, right-click on the iTunes program - this may be listed as either iTunes or iTunes.exe. Once you have done so, choose "Properties" from the menu that appears.
7) Click on the "Compatibility" tab, and uncheck the option to run in Compatibility Mode if it is selected.
8) Click "OK" to accept the new settings.
One of these two solutions should hopefully resolve the problem, but I would strongly suggest visting Apple's support homepage for more information if you are unsure of how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Apr 13, 2008 | Audio Players & Recorders
Apple iTunes Logo
69 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
