Question about Brother MFC 210C All-In-One InkJet Printer
The "keep printed documents" stays checked after i uncheck it!
The "keep printed documents " will not uncheck for me to print store coupons. they state that this must be shut off but it continues recheck after i uncheck it
Had the same thing happen. Go to properties, then advanced and check "print directly to printer". You'll be able to print your coupons. Make sure you go back to your previous settings when not printing coupons.
Posted on May 28, 2008
I Have An HP D145 Printer That Won't Print Some Online Coupons Or Will Only Print Portions Of Them. Any Advice? Thank You
Most likely this is an issue with the way the website is displaying the coupon. Check to see if there is an option to print coupon. You might also try to create a PDF copy of the coupon and then printing the PDF document. Finally, one other thing you could try is to take a screen capture of the coupon, save as an image file or PDF and then print as an image or PDF. Hope this helps.
Jul 11, 2011 | HP OfficeJet d145 InkJet Printer
I have a iMac G5 with 10.4.1. I try to print coupons on my hp laserjet 1320 and they stay in the que. Word docs print fine but any time i try to print any kind of coupon from any site, it messes up the...
If you are printing PDF coupons, that is probably the case, you need to upgrade the memory on the printer if you want faster printing on those types of documents.
Mar 22, 2011 | HP LaserJet 1320 Printer
How can I turn off the Keep Printed Documents selection?
First right click the printer icon in the SysTray (by the time usually) clear all documents.
Then pull the power cord and leave it unplugged for a few minutes, When you plug it back in the the memory in the printer should be clear.
Dec 10, 2009 | Brother MFC-3240C All-In-One InkJet...
Will not Print online Coupos
Just fixed my Brother HL-5140. Hope this helps :) I have struggled for years and finally figured this out from the Brother website.
If you are unable to print coupons from the Internet the print processor
setting in the driver needs to be changed. To change the setting,
1. Open Printers and Faxes.
2. Right mouse click on the Brother printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Try printing the coupons again.
Aug 20, 2008 | Brother HL 5140 Laser Printer
Deletes and reinstall print drivers, does'nt sound like a printer problem, more software issue, driver reinstall is my best bet
What are you printing from? ie program is?, and can you print windows test page OK?
Dec 19, 2007 | Brother HL 5140 Laser Printer
If you have a Brother printer please change the following:
Start -> Control Panel -> Printers and Faxes -> Right click on your selected printer and select "properties"
Go to Advanced tab -> Print Processor
Change the settings from "BRMFC" print to "WinPrint" and set default to "raw" and Click Apply
Now go back to uncheck "Keep Printed Documents" and attempt to print the coupon.
I am a big fan of coupons.com, their tech support guy sent me these instructions. Good Luck!!
Nov 20, 2007 | Brother MFC 420CN All-In-One InkJet...
KEEP PRINTED DOCUMENTS
I in the Properties=>Advanced tap, select the option "Print directly to the printer". This will resolve your issue.
Oct 31, 2007 | Brother DCP-110C All-In-One InkJet Printer
Printing problem
Go to MFC5840CN Printer Properties -> Advanced 2. Click on Print processor 3. Select Winprint, then click OK 4. Uncheck 'Keep printed documents', then click OK 5. Go back to Printer Properties -> Advanced again to make sure the option is unchecked.
Sep 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
364 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
