Question about Home
My toilet won't stop running.... I replaced the ball and that did not work. If I raise the ball up it stops running, but when I raise the ball it's above the top of the tank. I think I need to lower the water level in the toilet, how do I do that?
  • 43,501 Answers
Two ways....
Either turn the screw down at the back of the rod where it pushes down on the valve or grab the rod with both hands and bend the rod so that the ball sticks further down into the tank...
heatman101
Posted on Sep 27, 2010
Water wont stop running
Water is either running (1) into the overflow tube or (2) out to the toilet under the flapper at the bottom of the tank. If (1) lower the ball or float. Done differently depending on model. If (2) replace the flapper with new flapper designed for your model. (Note: Raise manually the float valve and if water still runs out the little tube that goes into the overflow tube then fill valve is defective. Replace it.)
Mar 24, 2013 | American Standard Home
Water runs intermittently when toilet has sat idle
Hi aselbst...
Water running is an indicator that the "Ball ****" water inlet device is leaking by, there is no fix to this problem.
You must replace the ball **** to stop the water from leaking,
The ball **** is non-repairable.
You can try to adjust the float to a lower level, sometimes that will work to stop the leak
Please take time to rate me
Sep 03, 2011 | Kohler Cimarron Comfort Height elongated...
We just installed the Cimerron two piece. After flushing the toilet, it will not stop running. Water just goes into the over flow section.
  • The exact cause of a Kohler Cimarron toilet running non-stop depends on the exact model of toilet owned. In some, the lift chain connected to the handle can become kinked, preventing the ball seal from covering the drain completely. Just unkink the chain to fix this. In other cases, the float ball is stuck against the side of the tank, preventing it from returning to its normal horizontal position. When this happens, the toilet's tank doesn't stop filling with water. The excess continuously flows into the overflow pipe. Dislodge the float ball from the side of the toilet and this should clear the problem. Likewise, you might consider shortening the armature on which the float ball sits, so it won't become stuck again.
  • Read more: Troubleshooting a Kohler Cimarron Toilet ' eHow.com http://www.ehow.com/how-does_5017443_troubleshooting-kohler-cimarron-toilet.html#ixzz1CxKmz9ZQ
    Feb 04, 2011 | Home
    How to stop running water in tank
    Replace the "Ball ****" ...it is non-repairable...it is the part that regulates the water level in the toilet tank...also check the "Flapper Valve", if it is worn it will cause the toilet to leak.
    Please rate me
    Dec 31, 2010 | Toto Toilets ST784S 12 Sedona Beige...
    Toilet doesn't turn off after flush
    The Kohler Cimarron is one of the most popular and reliable toilets out there. (My Favorite). However, depending on the hardness of the water and if you use cleaner tabs in the tank, these factors can lead to a malfunction.
    The first thing you should do is hold the flapper (rubber seal inside the tank that releases the water down to the bowl) down with your hands for a few seconds after a flush and see if the toilet stops running. Sometimes the flapper doesn't seal properly therefore the fill valve keeps working non stop. Stopping the fill while holding the flapper down will confirm that your flapper needs to be changed.
    If this doesn't work then try this....
    The other common problem with a running toilet is with the fill valve itself. There is an attached float on the fill valve that goes up and down depending on the water level. Once the water level rises, it rises the float, and the float tells the fill valve to stop filling the tank. While the toilet is running (hissing), try raising the float all the way up with your hand and see if it stops. If it stops but not consistently with every attempt, then you will need to change the fill valve. I believe the Fluidmaster 400A is the replacement model.
    Nov 23, 2010 | Kohler Cimarron Comfort Height elongated...
    Toilet is constantly running into bowl..have replaced flap with no difference
    Change your Ball ****...(Water inlet Device)
    You can also make sure that the water level is not set too high in the tank and overflowing into the overflow tube...if it is try to readjust the float to seal the water from getting into the tank. If you cannot readjust the float to stop the water from entering the tank then you must replace the Ball ****.
    This is a free answer, Please rate me
    Oct 17, 2010 | Eljer Toilet Onepiece Canterbury ...
    Archer tank always running. don't know how to fix
    If there is always water running into the toilet bowl, replace the tank ball. That's the stopper at the bottom. If you can lift the float and stop the water, either replace the sealing diaphram at the top of the ballcock (float valve) or replace the whole unit. Some are not repairabe.
    Oct 31, 2009 | Kohler Archer Toilet Tank, Almond
    The gmax continues to run and won/t stop
    if it worked fine and now it has stopped....then there is no adjustment that will fix it. If the fill valve is not shutting off you either need to replace the seal in the valve or get a new fill valve. If the water is leaking past the flapper you will need a new flapper.
    Oct 20, 2009 | Toto Drake ADA Compliant Toilet with...
    My toto toilet keeps running
    if its a metal arm connecting the ballcock shut off valve to the float flush it and bend the metal so the float is lower. if u can adjust the ball **** lower then do so. the shut off is not shutting off cause the float isnt going high enough. and the excess is going down the overflow.
    Nov 29, 2008 | Home
    Home Logo
    143 people viewed this question
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
