Question about Singer Sewing Machines
Bobbin thread is bunching under the fabric what is causing this?
  • Singer Master
  • 7,365 Answers
Check the needle to see if it's bent
check to make sure the needle & thread are right for the project
some sewing machine bunch under fabric when the top thread come off the thread take up lever
Posted on Sep 28, 2010
I checked my thread and bobbin watch the video and my machine keep bunches the bottom stitch
Is it really the bobbin thread that is bunching? Generally, thread messes under the fabric are the fault of the top thread, and thread messes on top of the fabric are a bobbin problem.
Top thread bunching under the fabric is called "thread nesting" or "bird nesting" but I prefer to call it thread "barfs." Most often, it occurs because the top thread has not been seated completely in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
RAISE the presser foot and rethread the top thread.
(Verify the thread path is correct.)
Set the top tension disk at the midway point.
Retest your machine. Tweak the top tension if required.
Mar 27, 2017 | Sewing Machines
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
Bobbin issues the bobbin thread is bunching up
Check whether it is bobbin thread or the top thread accumulating under the fabric. Generally, if thread problems exist "under" the fabric, it is a top thread issue. If the problems exist "above" the fabric, it is a bobbin issue.
Sounds like a thread nesting (bird nesting) problem where the top thread is globbing under the fabric. Usually, this is caused by misthreading (confirm the thread path), the thread not seated in the tension disk (ALWAYS RAISE the presser foot when threading!), or very loose top thread tension.
Remove the thread. Raise the presser foot and rethread from the beginning. Check that the thread path is correct. Set the upper tension at the midway point between high & low numbers (this is the beginning point for tension and will most likely need to be tweaked for your particular machine).
Sewing Machine Thread Bunching Up Here Why
Dec 11, 2016 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Doesn't sew correctly under fabrics ,top is ok
To give you useful information it would help to describe your machine and your problem in detail.
Mar 07, 2016 | Sewing Machines
Why isnt my bobbin thread being caught by the upper thread?
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever?
May 24, 2015 | Sewing Machines
My bobbin won't move to add thread to it
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever?../
Feb 09, 2014 | Brother CS-6000
The thread on the bottom bunches up all down at the bottom than bunches up
Usually problems like this are caused by improper bobbin winding and installation, incorrect tension, the wrong needle for project, or simply not grasping the threads and gently pulling them backwards when you start a seam.
1. Make sure you are threading the machine correctly.
2. Check your tension.
3. Check the bobbin, make sure it's wound properly and that you don't have the bobbin in upside down.
4. Check for bits of fluff and thread in the bobbin race area.
5. Change your needle, they wear out, get bent, dull... etc. You should have several different types on hand at all times.
6. Grasp both the threads gently and pull slightly backwards when you begin a seam. this will assure that your bobbin thread doesn't get all bunched up under the fabric.
7. Always test tension, needles etc., on a scrap piece of fabric before you begin sewing your project.
:o) Smile... sewing is fun... remember?
Mar 04, 2011 | Singer 3116 Simple
Sewing Machines Logo
241 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
